460 motor mounts in a 68 f100
Jerry, It is a two piece system. Motor mounts are bolted to the engine and in turn are bolted to the perches aka engine stands. I have never delt with a 460 so I don't know what perches will or will not work. It very well could use the same a the I-6 & 352/390. I do know the 302/351W uses a different swept back perch.
There shouldn't be any difference in motor mounts between the car & truck, but should be on the perches. The engine bays are the same configuration from 65 to 79 and 460s were offered in the late 70s, therefore my recommendation to find late 70s 460 perches to use in your truck.
kapeesh??
John
kapeesh??
John
on
1 Post
i have a 77 lincoln 460 in my 67 f100.the mounts i used were from a late 70's truck with a 460 and they are a 3 piece deal.these are your best bet if you can find a set,also grab the truck manifolds if you can.the lincoln manifolds stick out a little too far and are way too close to the frame making the exhaust pipe very difficult to attach to the passenger manifold.as for the tranny you are using,it would be easier to find a truck c6.
you gotta think ahead,if the lincoln tranny takes a dump then you'll have to put another lincoln tranny in it's place.the c6 truck trans can be found behind the 351m/400's and will work with the 460.also,you may have to move your crossmember back a little and drill new holes to bolt it down(easy).
shameless plug here ,but my truck is for sale with the 460 already in and running.$2,500 obo
thanks for the info. i will keep an eye on the tranny issues.
found the mounts at l&l for 125. looks to be just what the Dr. ordered.
i am thinking of throwing headers on this beast (if you are going to be a bear, be a grizzly). with an edelbrock intake, anybody have a rough guess on dyno numbers? it has a .30 over and is slightly above stock. i am thinking that back in the day, that engine rated at around 360hp. i am thinking i should push 375-400. thoughts?
peckman
24
01-13-2014 06:52 PM
Princeofrogs
02-14-2012 06:22 AM
Fordman7780
10-01-2002 09:21 AM
