Tow Command - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Tow Command
Old 10-15-2004, 09:54 PM
bcnu2004 bcnu2004 is offline
bcnu2004 is starting off with a positive reputation.
Tow Command
I have been searching my local dealers inventory on the Ford website for F250's and I haven't seen a one with the new tow command option listed under the options on the window sticker. Is this included in the tow package option or listed seperately. I am asking how it should be listed on the window sticker. On the build your own truck section on the Ford website it is listed as a option seperately but you must include the new torqueshift trans. Thanks in advance for any info!
Old 10-16-2004, 09:44 AM
1olddog2 1olddog2 is offline
1olddog2 is starting off with a positive reputation.
mine was listed by its self itsays ''tow command system'' on my window sticker
Old 10-16-2004, 11:26 AM
1956MarkII 1956MarkII is offline
1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.1956MarkII has a very good reputation on FTE.
The tow package is standard on all Super-Dutys, the TowCommand is a separate option. NONE of your local dealers have ordered even ONE with the TowCommand? Can you say "moron dealers?" I wouldn't order one without it!
Old 10-16-2004, 11:30 AM
gregmck gregmck is offline
gregmck is starting off with a positive reputation.
What I've found during my shopping it that around here all the KR's have the Tow Command, none of the others have it. There are exceptions, but very few. I asked one dealer why they would ever order even one truck w/o it and I just got a blank stare.
Old 10-16-2004, 11:39 AM
Hellrazor1 Hellrazor1 is offline
Hellrazor1 is new and has a neutral reputation at this point.
Its up to the dealer what he orders on the lots, around here you see one dealership with 70% diesels and the other has none.
Old 10-16-2004, 11:59 AM
Quote:
Yes that is what I thought also. To me this would be a option that most people would want. But not a one has it on the window sticker when I do a search of my local dealers in my areas inventory on Fords website. Also I have noticed that most every truck they have is diesel and only 1 or 2 gas.
Old 10-16-2004, 12:03 PM
marspec marspec is offline
marspec is starting off with a positive reputation.
I remember reading somewhere that 80-90 percent of Super Duty owners tow. It would only seem logical to find a few on the lot with the Tow Command System even though Ford did not see fit to include it as standard equipment.
Old 10-16-2004, 12:27 PM
04superduty 04superduty is offline
04superduty is starting off with a positive reputation.
unfortunately logic and dealer dont go well together, like oil and water.
Old 10-16-2004, 09:34 PM
rver rver is offline
rver is starting off with a positive reputation.
Is there a Difference?
I guess I'm getting confused by this discussion about the tow comand system in the superduty's...... If you have the 6.0 diesel, with auto trans., my dealer spec says it comes with the "tow/haul mode" on the tranny.... I also have ordered (as options) the integrated brake controller and the receiver hitch...... Does this mean my new (and as yet undelivered) F350 will or will not have the tow command system? Just what is the tow command system if it isn't these options (6.0,auto,ibc,receiver hitch)?
Old 10-16-2004, 10:12 PM
This is on Fords website:TowCommand System (requires TorqShift™ automatic transmission) <!--rmore-->Includes TowCommand Integrated Trailer Brake Controller, manual telescoping trailer tow mirrors with manual glass on XL, manual telescoping trailer tow mirrors with power/heated glass and integrated clearance lights/turn signals on XLT and Lariat (available on XL to Fleet only and requiring Power Equipment Group)
The tow haul mode will make your trans shift more firm when towing as not to build up as much heat. You can order the brake controller by itself also and not with the tow command system.
Old 10-16-2004, 10:13 PM
Rogue427's Avatar
Rogue427 Rogue427 is offline
Rogue427 has a good reputation on FTE.Rogue427 has a good reputation on FTE.
Towcommand
I just ordered a 05 F350 XLT FX4 with the towcommand sys. Order code is 91T retail $425.
Old 10-17-2004, 09:05 PM
Thumbs up It is confusing a bit, isn't it?
In checking the Ford website to determine what this tow command is all about, I think I now understand it but it is confusing....if what I say here is felt to be incorrect, then will somebody plse clarify..
The tow command system is not really just one item but rather it is a combination of options which when added to the vehicle create a state whereby the driver has much better "command" of his/her towing situation.
The tow command system consists of:
1- the automatic transmission (with the tow/haul mode feature included)
2- the heated/telescoping trailer tow mirrors with clearance lites
3- the integrated trailer brake controller (called a "TBC" by Ford)
4- the larger brake pads/calipers now included with all '05 model SD's.
I think that sums it up.
Hope I've clarified it for some and now clouded up the waters.
Old 10-17-2004, 09:07 PM
opps ---that last line should read
"and not clouded up the waters.
2014 trailer tow packages 350user 2009 - 2014 F150 3 02-15-2014 01:59 PM
Trailer Tow Package on Platinum 4x4 KingRanch250 2009 - 2014 F150 3 10-12-2009 10:10 AM
Need help explaining wrong GVWR SFO Car/truck Buying Advice 3 04-24-2005 07:44 AM
'05 Integrated Brake Controller ? dsweger 1999 to 2016 Super Duty 3 07-21-2004 01:26 PM
Factory window sticker drifter Explorer, Sport Trac, Mountaineer & Aviator 2 11-01-2001 07:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
