What is a "Shift Solenoid A"??????????????? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-14-2004, 08:10 PM
rscritch rscritch is offline
rscritch is starting off with a positive reputation.
Ive got a 99 F-250 Super Duty and the check engen light came on and i checked the codes and the read
DTC P0750
Shift Solenoid A
Malfunction
Does any one know what this part does, where its located, what system it is in, i have looked every where in my haynes manual and can't find any mention of this part, any help would be greatly appericated
thanks
Ryan
Old 10-14-2004, 08:21 PM
99PSDCREW 99PSDCREW is offline
99PSDCREW is starting off with a positive reputation.
Were there any symptoms?
Old 10-14-2004, 08:27 PM
In my Ford workshop manual Volume II page 307-01-30 is states:
"Shift solenoids A and B provide gear selection of first through fourth gears by controlling the pressure to the three shift valves."
I don't know where they are yet.
99PSDCREW
Old 10-15-2004, 05:11 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
They are inside the tranny.
Old 10-15-2004, 01:34 PM
there has not been any noticable problems as far as i can tell, just the check engen light came on, if its inside the trany any idea on how hard it might be to get repaired?
Old 10-15-2004, 01:55 PM
1ruralmailman 1ruralmailman is offline
1ruralmailman is starting off with a positive reputation.
not very you just have to drop the pan ,and valvebody to get to them. chances are though that the only thing that needs to have done is have the transmission case grounded with a heavy wire to the frame. this will take care of alot of these crazy tranny codes,with no noticeable symptoms.
Old 10-15-2004, 03:53 PM
so a faulty ground might be causeing the codes to trip my light, where is the factory ground located for the trans, that way i can inspect it and see if there is any thing wrong with it, even if theres a problem it dosen't soudns all that hard to fix
Old 10-17-2004, 11:12 AM
there is not one thats the problem, they count on the tranny being bolted to the block to do it.works good for a while, but over time with a aluminum tranny case ,and a cast iron block ,held together with steel bolts electrolosis sets in just enough to lose the ground. this makes the processor go into a "limp home" mode, and it will eventually will not shift right.
Old 10-17-2004, 09:28 PM
so i should run a ground to the tranny and see if that will fix the problem? any recomended spots to ground it at?
Old 10-17-2004, 11:58 PM
Outpost22 Outpost22 is offline
Outpost22 is starting off with a positive reputation.
Mine failed (shift solenoid) right after the tranny was rebuilt and Ford had to open it up again to replace it.
Old 10-18-2004, 05:22 PM
clean metal on the case,pull a bolt on the pan shine up the pan and yhe bolt. find a empty hole in the frame ,polish it up bolt it together, and youre done.
Old 05-07-2008, 12:08 AM
grberglund's Avatar
grberglund grberglund is offline
grberglund is starting off with a positive reputation.
So did cleaning up the ground and/or adding a ground strap to the tranny work? I'm very curious as I just replaced my solenoid valve body (p0755 Shift Solenoid B malfunction) and now I'm getting 3 error codes (p0755, p0750, P0743) and unfortunately some new shifting problems. My battery is pretty corroded which I'm sure isn't helping matters.
Old 05-07-2008, 05:06 AM
yes it did i mine.
Old 05-17-2013, 10:33 PM
philistine1 philistine1 is offline
philistine1 is starting off with a positive reputation.
Holy smokes. The ground trick seemed to work. Of course it took A few days for the computer to reset but an hour after ordering the solenoid pack the of light stops flashing and it shifts fine. Cleared the codes and nothing else coded. I thought for sure that this wouldn't work for me because it was shifting so badly and I just installed the engine 3 months ago no way this was a problem. But it is hot here. (AZ 100 degrees). And the P0755 code was only when it was hot out? Well see how it runs over the next few days. Solenoid pack gets here Tuesday as the backup plan now.
What am I seeing Mtnhermit 1999 to 2016 Super Duty 10 04-30-2016 12:57 AM
1950 F1 (o) Starter solenoid F1rb 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 08-24-2015 10:48 PM
4r70a overdrive issue Al Tamm Clutch, Transmission, Differential, Axle & Transfer Case 7 10-11-2013 09:15 AM
solenoid on starter Brother Les 1999 - 2003 7.3L Power Stroke Diesel 15 01-23-2013 10:08 AM
SHIFT SOLENOID VONxRUBENxLA Excursion - King of SUVs 3 10-03-2011 08:39 PM
Tags
2003, 4r100, diesel, dtc, duty, f250, ford, malfunction, p0743, p0750, p0755, po750, shift, solenoid, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
