Engine loping at idle speed - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-05-2002, 02:36 PM
Rand Rand is offline
Rand is starting off with a positive reputation.
Old 01-05-2003, 12:31 AM
mlkull mlkull is offline
mlkull is starting off with a positive reputation.
My engine is loping at idle speed. Also, I now have to pump the accelerator to start it (warm and cold), where I didn't before.
OBD was showing a P0401 (EGR flow insufficient) before this happened. I was going to check the EGR valve but didn't get around to it. Now I'm getting a P0402 (EGR flow excessive).
I'm not sure if the 402 is a symptom the cause. EGR flow shouldn't affect the engine starting, should it?
My Haynes manual shows a number of causes for the engine idling inconsistently. The first of which is vacuum hoses. It directs me to check the vacuum hoses near the throttle body. Question is, what does a vacuum hose look like? To what would it be connected?
Old 01-06-2003, 10:05 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Iffen the EGR is stuck open it will make it hard to start and have a crappy idle, if it will idle at all. A vacuum hose is just a piece of rubber tubing attached to the intake manifold for vacuum source, and attatched at the other end to a vacuum operated device, such as the power brake booster, or the mode select valve on the heater plenum.
One way to check the EGR operation is to have the vehicle idling, and open the EGR valve by pushing on the diaphragm. The engine should die or react with poor running, and clean up when you release the EGR. You can also disconnect the vacuum line hooked to the EGR valve, and plug it with a golf tee to see if the engine runs better..
tom
Old 01-06-2003, 12:02 PM
amp17757 amp17757 is offline
amp17757 is starting off with a positive reputation.
Sounds like your EGR valve is sticky, gunked up. If first you got the error code indicating INSUFFICIENT FLOW, then later, EXCESSIVE FLOW, the valve is "hanging up". Like "tomw" said, it will idle like crap (if it runs at all) when the valve is stuck open, but will run well when the valve is stuck shut (you might not even know it's stuck shut if the computer/check engine light didn't tell you). If indeed it turns out to be the EGR valve for sure, you might be able to salvage the existing one by gushing it out with WD-40, and working it manually to dissolve gunk & free it up. Let us know how it turns out.
Old 01-07-2003, 10:42 AM
I think I've found the EGR valve itself, but I want to make sure. I defintely found the EGR transducer. It's got two rubber tubes attached to it that run to a metal pipe which in turn runs to the manifold.
Now the other end of that pipe runs toward this circular object. The circular metal object has a tube running off it that runs to a rubber object attached to the engine. This rubber object has another rubber tube which runs behind the engine somewhere. The circular metal object is attached by two bolts to another metal pipe which leads right behind the throttle body. I believe this circular object is the EGR. I'll find out at least when I take it out today =)
Old 08-15-2008, 09:27 PM
Tomm Tomm is offline
Tomm is starting off with a positive reputation.
It may be the EGR, but then again like your Haynes manual stated, it could be a vacuum leak. That's what my problem turned out to be. The upper radiator hose totally split open a main vacuum line. I replaced it and solved the problem. She runs like new again. By the way, it was my 2002 4,0 Ranger.
Start her up, and listen for the hiss of a leak. As your Haynes manual describes, use a stethescope or a rubber hose to pinpoint the leak if you have to.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
