1951 F1 Spindles
1951 F1 Spindles
Hi all,
I am new to this group. I have a '51 F1 which is completly stock. The truck came out of Arizona and is in great shape.
My spindles will not take grease. I have tried everything to get grease into them. Are there any tricks to this? Could they have been put together wrong and thus not taking grease?
Thanks,
RickS
Thanks,
RickS
Are you talking about king pins? The spindles are what the wheel bearings ride on and you have to pack the bearings with grease to keep the spindles greased. Did you put new zerk fittings on the top of the pins? You should be able to pump grease in until it oozes out around where the shims and flat bearing is. Try new grease fittings. I don't see how you could mess up how they are installed.
Barry
50 F-1
Barry
50 F-1
It's a pretty common problem for my daily driven '48. The top ones always seem to get tight first.
Try lifting the wheels off the ground. Move them from side to side while you keep pressure on the greas gun. Remove the zerk and dig the hardened grease out of the fitting area as best you can. A shot or two of PB blaster or your favorite penetrating oil in the threaded hole can sometimes get a passage opened up for the grease to follow. Heat can also help. Perseverance will pay off and it'll steer like new. Then remember to grease on a regular interval.
Do you know if this axle had new king pins and bushings installed? If so, they may have installed the upper bushings wrong in not aligning the holes in the bushing with the hole in the spindle itself. That would not allow grease to flow thru to the king pin.
Try the air grease gun and if that doesn't work, you know that the holes are plugged or things are not aligned. You could always try to get the pin out and then try drilling thru to open the hole. It may be plugged with dried out grease and dirt after all these years.
Barry
50 F-1
Barry
50 F-1
JefflovesF250s
02-18-2020 08:26 PM
smithwoods
02-18-2020 07:44 PM
capriceragtop
04-22-2014 09:25 PM
jjones1988
03-18-2012 10:59 AM
