Mazda B4000 clutch problems - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-09-2003, 01:59 AM
tesai tesai is offline
tesai is starting off with a positive reputation.
I live in alaska and my b4000(ranger) is having clutch problems. the other morning it was about -30f and I started the truck. when it had warmed up for about 20 minutes i went to leave but half of the clutch throw was free play. the bottom half was not enough to allow me to shift into gear with the truck running. I could shift into gear with the truck turned off, but as soon as I started the truck with it in gear it would start to creep with the clutch all the way to the floor. I checked my master cylinder reservoir and it was low so i added fluid to the correct level but the clutch problem still wasn't resolved
Old 01-09-2003, 06:17 AM
mathelm's Avatar
mathelm mathelm is offline
mathelm is starting off with a positive reputation.
You didn't say what year it is, but it sounds like you need a new slave cyclinder. To change it you have to pull the tranny, so you should do the clutch while you're at it. I just had to do the one on my jeep and it is a pain. But I found a kit on ebay, and I've seen them for rangers on there too. I think I gave about $130 or so for mine. It might help if you bleed it few times. You may just have a little air in the line. I kept my jeep going for over a year by bleeding it before I finally broke down and changed it.
Hope this helps.
Old 01-09-2003, 07:38 AM
cheeup cheeup is offline
cheeup is starting off with a positive reputation.
89 f250 clutch issue Djhodges01 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-15-2015 06:28 PM
Clutch problem!! Engaged to floor is not engaged!! Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 10 11-10-2014 09:46 PM
Clutch Disengage Problem 96' RANGER bassriff333 Ranger & B-Series 2 10-31-2011 08:00 AM
Clutch safety switch iusse? Fordownsall Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-10-2011 09:40 PM
94 B4000 Nightmare...help please Doomhammer Ranger & B-Series 23 05-01-2009 06:55 AM
Tags
1996, 2001, 96, adjustment, adustment, b4000, bleeding, clutch, cylinder, masda, master, mazda, problem, problems, replacement, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
