Daystar leveling kit on a reg cab stx? - Ford Truck Enthusiasts Forums
Old 10-13-2004, 11:05 PM
KaNigIt KaNigIt is offline
KaNigIt is starting off with a positive reputation.
Im new to the forum so be nice. I have a regular cab stx and im really interested in the leveling kit but I measured the distance between the tire and the fender on the front and its 7.5" and on the back its 9.5". The Daystar kit says it raises the front end 2.5" therfore in theory it owuld be half an inch taller. Does the kit really raise it the full 2.5" and would it still be to high for a regular cab? Also how much should I expect to pay for the install? Lastly, is there a way i can order ford stock fender flares like on the FX4 model?
Old 10-14-2004, 11:20 AM
ejpreston's Avatar
ejpreston ejpreston is offline
ejpreston is starting off with a positive reputation.
Do some searches using google. There are a few kits that sell different spacer thinknesses depending on how high you want. Others on here have said the 2.5 does lift the front slightly higher, which is why other lift manufacturers (autospring, ezlift) make slightly shorter lifts. There are tons of posts on this topic in this forum, so enjoy reading them!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
