Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-13-2004, 08:09 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
Garage is empty, add now
scottie2hottie is gaining momentum as a positive member of FTE.
Question Wanna learn about flatheads....
I do not own a flathead now, but would like to someday. For now, I'll have to take gratification in just "knowing" about them...So, enlighten me. What is different other than the valve housing is part of the block? Speaking...how do you get to the valves? Use a 239 for example, as they're the most common and probably what I would own. How does the valve train work specifically? Is the bottom end the same as an OHV motor(crank, rods, pistons, etc)? Do they have onboard mechanical fuel pumps like later engines? What drives the oil pump? Anything you know, spill it unto me!
Thanks guys!
Scott
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
Proud to be an OHIO BOY
  #2 (permalink)
Old 10-13-2004, 10:12 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
http://www.fordbarn.com/earlyv8/forum03/
http://groups.msn.com/FordFlathead19...3/messageboard
On the MSN Site follow the links on the left side for additional info
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #3 (permalink)
Old 10-13-2004, 11:07 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Spend some time on this site too. Pictures are worth a thousand words.........
http://www.vanpeltsales.com/FH_web/flathead_home.htm
Basically they're the same as ohv engines, except the valve train which has no pushrods or rocker arms - the valve stem/lifter/cam are in direct contact. Gear on the rear of the cam runs the oil pump.
  #4 (permalink)
Old 10-14-2004, 04:23 PM
How does the exhaust go about getting to the side of the engine? Especially with the valve being on the inside...I'm just not seeing it....
Scott
__________________
  #5 (permalink)
Old 10-14-2004, 05:31 PM
You almost have to see one to figure it out, and then you'll go.......duh!
The exhaust drops below the valve through a passage in the waterjacket and out the exhaust manifold. The two middle ones use the same port which confuses a lot of people when they see 8 spark plugs and only 6 exhaust tubes.
Routing the exhaust thru the water jacket is one of the reasons flatheads are prone to overheating IF the engine and radiators aren't clean and timing isn't kept on the mark.
  #6 (permalink)
Old 10-14-2004, 08:08 PM
Loan Ranger Loan Ranger is offline
Loan Ranger is starting off with a positive reputation.
Go to www.store.yahoo.com/motorbooks/index and click on engine manuals. They have a really great book on the Flathead Ford engines! It is lavishly illustrated, including flow diagrams of the incoming fuel/air mixture and the exhaust gases as well!
It is really a great book, Scottie!
  #7 (permalink)
Old 10-24-2004, 04:05 PM
nailhead nailhead is offline
nailhead is starting off with a positive reputation.
Swing by your local Barne's and Noble.
Tex Smith's Complete Ford Flathead V8 Engine Manual is excellent,under $20, it covers the evolution of the flatty and modifications for hot rodders. Very good detail drawings of how they work too. Basically everything you would need to know.
It makes a good coffee table book.
__________________
95 F150 4X4 Supercab shortbox 302
Camburg long travel front, custom rear.
'35 pickup, '39 passenger suspension and juice brakes, '48 flatty.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
