high flow cat? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
high flow cat?
Old 01-09-2003, 06:03 PM
89ranger4_0 89ranger4_0 is offline
89ranger4_0 is starting off with a positive reputation.
high flow cat?
hey guys new to the forum here,i had a couple of questions.i have been considering pulling my pre heater/cat section out and replacing it with a high flow cat.have any of you guys done this?i would assume it would raise my powerband somewhat,i dont know if its worth doing or not,but i am a bit concerned about the high millage on my cat right now,and it beeing to much of a restriction.i'm running a 92' 4.0 in my 89 truck,mild cam,headers and flowmaster exhaust.also,did you expeirience any big exhaust sound volume changes switching over?thanks very much.
2nd,how does one search the forum databases?i'm sure this has all been discused before,but i could not locate a search feature for all the forums.thanks again!
Old 01-09-2003, 07:21 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
high flow cat?
Welcome to the board. If it's the original cat I think you would see some improvement.
Old 01-09-2003, 11:33 PM
Hank85713 Hank85713 is online now
Hank85713 is gaining momentum as a positive member of FTE.
high flow cat?
I have 94 4.0 5 speed 2wd. Just installed high flow cat, free flow muffler and 2.5 inch exhaust all the way from exhaust header to tail pipe. Truck has 98000 on it and it made a significant difference with just the exhaust. pulls easier in all gears, dont have to downshift as much. Gas milage went up but I also just installed new plugs. This was not a straight thru muffler its a magnaflow center in and out. Good mellow sound.
I will be installing a air intake from streetsmart designs next week.
Old 01-14-2003, 07:28 PM
COORS1 COORS1 is offline
COORS1 is starting off with a positive reputation.
Post high flow cat?
COHO Hi I'm new to this vast wealth of info.and I think itis amazing. I have a 94 3.0 ranger 5speed 4x4. and I was hoping some one could help me determine which Magna Flow muffler will work on my truck.I want to go with 2.5 pipes and a Magna Flow because it is straight thru design, and I need some more power. If all the mufflers are the same on the inside , is it a matter of getting the same size as your original or someother formula? Any suggestions will be greatly apprciated. Thanks
Old 01-15-2003, 09:06 AM
Ken00's Avatar
high flow cat?
I wouldn't go any bigger than 2.5 for a single, I would prefer 2.25, 1.75-2.0 for a dual exhaust. If you go any bigger on a small V-6 it will end up hurting the exhaust flow. The mufflers are really only going to affect the sound when you get into performance ones.
Old 01-15-2003, 04:02 PM
Post high flow cat?
I plan to go with a single pipe, but is a straight thru muffler like Magna Flow too much, or would it be better for exhaust flow and power to use a Flow Master 40 for this little v-6? Also, I have 2 cats on my truck, if I decide to replace them do I need to replace both or can I use one performance cat legally and will it give me more power?Thanks for yhe help
Old 01-15-2003, 08:50 PM
Ken00's Avatar
high flow cat?
The pipe diameter is all that is important, the muffler flow won't matter.
Old 01-16-2003, 12:28 PM
Post high flow cat?
What should I do about the cats? Can I get away with one cat legally and emission wise, or do I need to replace both of them?
Old 01-16-2003, 03:53 PM
Ken00's Avatar
high flow cat?
I would check with the manufacturer to determine exactly what it will replace on your truck.
Old 01-16-2003, 04:05 PM
alamantrick alamantrick is offline
alamantrick is starting off with a positive reputation.
high flow cat?
Old 01-22-2003, 09:21 PM
high flow cat?
Coors1 you can replace the 2 piece cat with a high flow single. Biggest problem is the fitting the cat to the exhaust headers, on mine they were oval and the guy had to do some metal fabbing to get it lined up and hooked up. He told me the cats are th biggest constrictors, they start out at about 2.5 in and neck down to 2 inch at the muffler. I went with a magnaflow that has baffles, not as noisy as the one packed with sainless steel. Guy said it holds up better and is not as noisy. It is pretty mellow not as high pitched as the little cars with their high noise mufflers.
Old 01-23-2003, 12:46 AM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
high flow cat?
Replacing the 2 cat setup with one is not legal where I live. I had to have some work done on my Bronco a year or so ago. The guy at the muffler shop told me that by state law (Washington), if a vehicle comes in with 2 cats, it has to leave with 2 cats. In my case, my Bronco only had 1 when I went in, so I was able to just install 1 high-flow cat and be done. If you live in an area where emission testing is done, especially if they do a visual as well, be sure to check out the rules regarding cat replacement. It would be a shame to spend a lot of money on a fancy exhaust system and then fail inspection on a technicality.
Old 01-23-2003, 06:30 AM
mathelm's Avatar
mathelm mathelm is offline
mathelm is starting off with a positive reputation.
high flow cat?
It's my understanding that the rangers don't have two cats. They have a "preheater" and a cat. But all those rules n regs are open to interpitation. You can go to one place and they fail it, go across the street and it passes with flying colors. The only thing that should matter is what comes out the pipe, not how it got there.
High flow cats are expensive. Worth it? Skandocious 1987 - 1996 F150 & Larger F-Series Trucks 11 04-29-2007 07:36 PM
Exhaust questions mightypan42 Exhaust Systems 3 12-02-2005 11:16 AM
Exhaust wjawill 1978 - 1996 Big Bronco 3 04-11-2005 09:48 PM
Clogged Cat symptoms MustangGT221 Exhaust Systems 6 08-22-2004 01:16 PM
V10 dual exhaust Big money Modular V10 (6.8l) 5 02-06-2004 11:28 AM
Tags
30, cat, flow, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
