Dim Headlights
Old 10-12-2004, 04:58 PM
kmurphy3251's Avatar
kmurphy3251
kmurphy3251 is offline
Dim Headlights
Howdy everyone. I have an interesting problem and was curious if anyone else has experienced this:
I noticed the lights on my '04 Screw (Lariat) are a little dim at night. Brights are great but the dims are pretty dim. I switched the switch over from "automatic" to "on" and they are much brighter on "on" then on "automatic". Has anyone else experienced this situation???
TIA,
Ken
Old 10-12-2004, 05:02 PM
Mezmo's Avatar
Mezmo
Mezmo is offline
Havent noticed any difference on mine...............04 SCREW LARIAT
Old 10-12-2004, 09:02 PM
04SCREW's Avatar
04SCREW
04SCREW is offline
You're Not Crazy
The lights on my screw does the same thing. I thought that it was just my imagination so I never mentioned it.
Old 10-12-2004, 10:18 PM
Patinabq's Avatar
Patinabq
Patinabq is offline
My F150 Lariat screw is equipped with the DRL feature and the lights are made to be dim with this feature. Your owners manaul has this info in it.
Old 10-12-2004, 11:05 PM
ATCS2004's Avatar
ATCS2004
ATCS2004 is offline
What is the DRL feature?
Old 10-13-2004, 06:43 AM
ctfordguy's Avatar
ctfordguy
ctfordguy is offline
Daytime Running Lights
Old 10-13-2004, 07:57 AM
kmurphy3251
Thanks for the response. If I understand the DRL system, it should switch from DRL to normal lights when it is dark enough to need them. I wonder if the sensor on mine is not making the switch....thus DRL at night.
Old 10-13-2004, 08:37 AM
Dr No's Avatar
Dr No
Dr No is offline
DRL is not available in the USA on the 2004 F150. Only available in Canada.
Mike
Old 10-13-2004, 11:59 AM
Mezmo's Avatar
Mezmo
Mezmo is offline
does it have anything to do with your fog lights being off?
Old 10-13-2004, 12:01 PM
kmurphy3251
My fog lights are turned "off."
Old 10-13-2004, 01:38 PM
Mezmo's Avatar
Mezmo
Mezmo is offline
I have my lights on automatic setting(all the way left) and pull the **** out so the fogs are running with headlights. It is a lot brighter with the fogs and the running lights on at the same time.
Old 10-14-2004, 12:11 AM
hunkster's Avatar
hunkster
hunkster is offline
It's brighter where you don't want it with fog lights on. Unless you're only going 10 mph, you will be looking much further ahead than the illuminated area of the fogs. I especially hate fog lights at highway speeds 'cause they make my night vision worse and just seem to "strain" the peepers. YMMV
Old 10-14-2004, 06:56 AM
theisen_4's Avatar
theisen_4
theisen_4 is offline
Just for fun, I switched my headlight control from "auto" to "on" and there is a slight increase in brightness while "on". I wonder why this is?
Old 10-14-2004, 07:48 AM
kmurphy3251
Theisen,
That's my original question. I don't know if it's "just the way they are" or if it's a problem. Mine is quite a bit brighter on "on" then auto. My best guess is that it is a shorter "path" directly from the on switch to the headlights than through the photocell (darkness detector) and then back to the headlights when the switch is set to "auto." I really don't think there should be much, if any difference. Interesting
Tennessean
Electrical Systems/Wiring
01-21-2015 02:35 PM
MoreBoostPlease
09-21-2010 04:57 PM
riverrat2
07-29-2008 05:59 AM
bmaguire36
1997-2006 Expedition & Navigator
07-16-2008 11:48 PM
CollinsCD
02-20-2002 12:24 PM
Quick Reply: Dim Headlights
