Dim Headlights - Ford Truck Enthusiasts Forums
Dim Headlights
Old 10-12-2004, 05:58 PM
kmurphy3251 kmurphy3251 is offline
kmurphy3251 is starting off with a positive reputation.
Dim Headlights
Howdy everyone. I have an interesting problem and was curious if anyone else has experienced this:
I noticed the lights on my '04 Screw (Lariat) are a little dim at night. Brights are great but the dims are pretty dim. I switched the switch over from "automatic" to "on" and they are much brighter on "on" then on "automatic". Has anyone else experienced this situation???
TIA,
Ken
Old 10-12-2004, 06:02 PM
Mezmo Mezmo is offline
Mezmo is starting off with a positive reputation.
Havent noticed any difference on mine...............04 SCREW LARIAT
Old 10-12-2004, 10:02 PM
04SCREW's Avatar
04SCREW 04SCREW is offline
04SCREW is starting off with a positive reputation.
You're Not Crazy
The lights on my screw does the same thing. I thought that it was just my imagination so I never mentioned it.
Old 10-12-2004, 11:18 PM
Patinabq Patinabq is offline
Patinabq is starting off with a positive reputation.
My F150 Lariat screw is equipped with the DRL feature and the lights are made to be dim with this feature. Your owners manaul has this info in it.
Old 10-13-2004, 12:05 AM
ATCS2004 ATCS2004 is offline
ATCS2004 is starting off with a positive reputation.
Quote:
What is the DRL feature?
Old 10-13-2004, 07:43 AM
ctfordguy ctfordguy is offline
ctfordguy is starting off with a positive reputation.
Daytime Running Lights
Old 10-13-2004, 08:57 AM
Thanks for the response. If I understand the DRL system, it should switch from DRL to normal lights when it is dark enough to need them. I wonder if the sensor on mine is not making the switch....thus DRL at night.
Old 10-13-2004, 09:37 AM
Dr No Dr No is offline
Dr No is starting off with a positive reputation.
DRL is not available in the USA on the 2004 F150. Only available in Canada.
Mike
Old 10-13-2004, 12:59 PM
does it have anything to do with your fog lights being off?
Old 10-13-2004, 01:01 PM
My fog lights are turned "off."
Old 10-13-2004, 02:38 PM
I have my lights on automatic setting(all the way left) and pull the **** out so the fogs are running with headlights. It is a lot brighter with the fogs and the running lights on at the same time.
Old 10-14-2004, 01:11 AM
hunkster hunkster is offline
hunkster is starting off with a positive reputation.
It's brighter where you don't want it with fog lights on. Unless you're only going 10 mph, you will be looking much further ahead than the illuminated area of the fogs. I especially hate fog lights at highway speeds 'cause they make my night vision worse and just seem to "strain" the peepers. YMMV
Old 10-14-2004, 07:56 AM
theisen_4 theisen_4 is offline
theisen_4 is starting off with a positive reputation.
Just for fun, I switched my headlight control from "auto" to "on" and there is a slight increase in brightness while "on". I wonder why this is?
Old 10-14-2004, 08:48 AM
Theisen,
That's my original question. I don't know if it's "just the way they are" or if it's a problem. Mine is quite a bit brighter on "on" then auto. My best guess is that it is a shorter "path" directly from the on switch to the headlights than through the photocell (darkness detector) and then back to the headlights when the switch is set to "auto." I really don't think there should be much, if any difference. Interesting
Stereo Dimming wiring question Tennessean Electrical Systems/Wiring 10 01-21-2015 03:35 PM
Dim Headlight after 05/07 Upgrade MoreBoostPlease Excursion - King of SUVs 5 09-21-2010 05:57 PM
Light are Dim riverrat2 1987 - 1996 F150 & Larger F-Series Trucks 5 07-29-2008 06:59 AM
Dim LED odometer bmaguire36 Expedition & Navigator 2 07-17-2008 12:48 AM
Dim Dash panel Lights CollinsCD 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-20-2002 01:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
