Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Illinois Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
  #1 (permalink)
Old 10-12-2004, 11:50 AM
daddubo daddubo is offline
Garage is empty, add now
daddubo is starting off with a positive reputation.
S/D Front wheel bearrings
Hi every one I was wondering if any one has tryed to grease the front wheel bearrings on a S/D? I tryed to get the spanner nut off but no luck any ideas?
Also does any one know if pre-99 S/D front steering nuckles and axels from a F 250-350 will inter change so I can go back to the old style hubs and bearrings?
Thanks Frank
__________________
2000 S/D XL 4dr 4X4 5.4 K&N Poweraid spacer 285x75x16
Western 8' Pro Plow
  #2 (permalink)
Old 10-12-2004, 03:03 PM
Fastronald's Avatar
Fastronald Fastronald is offline
Fastronald is starting off with a positive reputation.
Information
If no one answers right away..contact Fairmontman79@yahoo.com , He's the chapter's tech coordinator. Fastronald
__________________
Welcome to AMERICA.....now learn to speak english!
To ALL my fellow Veterans, Thanks!
U.S. Army 1971 - 1974
Founding F.T.E. Illinois Chapter Leader - 2004 - 2005
  #3 (permalink)
Old 10-12-2004, 11:05 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
The Super Duty unit bearing assembly is a non serviceable unit.
I'm not sure if any of the earlier stuff would work....if it did I'm sure lots of people would have done it by now.
I ditched the unit bearing setup and have inner and outer wheel bearings that I can repack with grease on my '01 F-350 since I went to the Dynatrac SD Combo that works on 6-12" lifts.
I know Dynatrac is working on a kit that will work on stock trucks that will include new wheel hubs, inner and outer bearings, races, seals, fixed spindles, spanner nuts, 35 spline outer shafts, and Warn premium locking hubs. I just called yesterday since we have a customer interested in this new kit and it should be released very soon.
Hope this helps.
__________________
DC
2001 F-350 PSD 4x4 Hell Raiser, Heavily Modified
2007 F-350 PSD 4x4 Work Horse, Moderately Modified.
Other 2wd PSDs: 99 F-450, 00 F-450, 01 F-350, 02 F-350, 02 F-550, 04 F-450, 06 F-450
  #4 (permalink)
Old 10-13-2004, 09:48 AM
Thanks I have seen them advertised but was looking for something I don't have to spend a couple of grand on. Do you know how long the stock ones will last I don't have a lift but I do snow plow.
__________________
Western 8' Pro Plow
  #5 (permalink)
Old 10-13-2004, 12:05 PM
DCSpecial's Avatar
The amount of miles you get out the unit bearings vary.....I've seen people who have had them go before 20,000 miles stock and others that get over four times that amount of mileage out of them. I pulled mine off with 28,000 miles on them with 35s on since it had 2000 miles and I didn't have any play in them and they weren't making any noise yet.
The new Dynatrac setup is less than a couple grand. For what the dealer charges on the unit bearing assembly you'd break even if you would have burned out 3 of the unit bearings.....but you also have the upgraded 35 spline outers and Warn premiums with the new kit as well.
Hope this helps.
__________________
DC
  #6 (permalink)
Old 10-13-2004, 12:36 PM
Thanks I will investagate them maybe the price has gone down since they first came out I've heard that the stock ones are about $400 ea.
Did the conversion take the wonder out of the steering that the S/D's are known for.
__________________
Western 8' Pro Plow
  #7 (permalink)
Old 10-13-2004, 05:28 PM
DCSpecial's Avatar
My truck never had any wander.....and still doesn't with the new setup.
But, the new Dynatrac setup that would work on your truck wouldn't change any of the steering components.
The price on the Super Duty Combo that includes new knuckles, drag link, trac bar, tie rod, etc... hasn't gone down....it's still $2995 + $198 if you have ABS.
I don't think that the new kit I'm referring to is even on their website yet since it hasn't been released yet. I just know about it since we're able to start taking orders for them already.
__________________
DC
  #8 (permalink)
Old 10-14-2004, 02:08 PM
Thanks again
__________________
Western 8' Pro Plow
  #9 (permalink)
Old 10-22-2004, 06:43 PM
bogginf350's Avatar
bogginf350 bogginf350 is offline
bogginf350 is new and has a neutral reputation at this point.
You can remove the caliper, roter and abs plug with the small allen head screw that holds it to the unit bearing and pump grease into the bearing from there. Just remove your grease zerk end from your grease gun and the 1/8 inch Npt threads fit tight enough to pump grease into the bearings. I would not recomend over doing it. And make sure to use a very high quality grease syn. pref.
__________________
Josh Davis, FTE resident injector builder.
03 f350 srw 4x4 6.0..
94 f1504x4 shortbox 523ci A heads
79 f1504x4 shortbox 547ci Blue thunders...
  #10 (permalink)
Old 10-22-2004, 11:26 PM
I don't havr front ABS will this still hold true?
__________________
Western 8' Pro Plow
  #11 (permalink)
Old 10-23-2004, 08:30 AM
bogginf350's Avatar
I am not sure if they have the provision or not, I doubt it honestly..
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
