Why is my Bronco so Dusty? - Ford Truck Enthusiasts Forums
Old 10-12-2004, 10:15 AM
raldo_gtm's Avatar
raldo_gtm raldo_gtm is offline
raldo_gtm is starting off with a positive reputation.
I wonder if anyone has this problem. When I go off roading, the interior gets dusty. I checked the weather stripping and it looks all good to me. The tailgate also looks fine, so what's the deal?
Old 10-12-2004, 10:16 AM
JBronco's Avatar
JBronco JBronco is offline
JBronco is starting off with a positive reputation.
There must be a leak somewhere near the tailgate - but I think that dust gets in no matter what, even with good seals. I don't think that there is much that we can do to stop it. I just replaced most of the seals back there, I will have to see if it still gets dusty.
Old 10-12-2004, 01:47 PM
AKBronco96's Avatar
AKBronco96 AKBronco96 is offline
AKBronco96 is starting off with a positive reputation.
I have the same problem. after offroading I have to hose out the seals really well to get the silt out. In doing this I noticed that lots of water came in around the weather stripping around the wing window, under the doors and under the tailgate. Mud comes in under the tailgate too.
Kim
Old 10-12-2004, 03:58 PM
raldo_gtm's Avatar
You know, I't noticed that I also have some water coming into the back passenger's side. When I was digging around for a possible sub-box, I seen that there was a damp spot under the rubber mat. I also had my windows tinted recently, and they could have soak the snot out of the back. But, I think that I'm going to trun on the Vent on High and use soapy water to locate the leaks.
Old 10-12-2004, 04:28 PM
AKBronco96's Avatar
The leaks in the seals don't bother me too much for now. I do alot of water crossings and mudding. so far, none of my passengers have gotten wet. I replaced my rear side windows a couple years ago. a rock bounced from a bellydumper off the highway and smashed the window in. I got tinted replacements for both sides from the salvage yard. looks good to me. I also use my truck for a bit of street dragging. lots of fun!!
Kim
Old 10-13-2004, 10:35 AM
Gary (UT) Gary (UT) is offline
Gary (UT) is starting off with a positive reputation.
I do a lot of driving on dusty roads on the west deserts of Utah. I have noticed most of the dust in my 94 comes in around the tail gate and the rear window gasket. It is probably time to replace all of the seals and gaskets.
Old 10-13-2004, 03:58 PM
JBronco's Avatar
Quote:
It is most likely the drip rails above the doors. They get tiny cracks in them and let rain inside the door which seeps down to the corner at the back of the door and soaks the spot that you are talking about. I just sealed mine, it has not rained yet but I sprayed water all over them and went through a car wash and so far it is bone dry.
tombob tombob is offline
tombob is starting off with a positive reputation.
Also choking in the dust
Man, tell me about dust! I have driven myself nuts trying to track down the cause of the dust entering my '80 Bronco. I have replaced door and tailgate seals as well as the rear widnow seals.
When going down a dusty road, a fine cloud of dust rolls in from under the passenger side dash. I suspect it is coming in the opening to the recirculation system. Very frustrating. To cut down the dust, I have to close windows, and et teh AC to Max setting--the AC does not work BTW, I thik it just pressurizes the interior a bit and slows down the dust.
Old 10-13-2004, 05:43 PM
raldo_gtm's Avatar
Yeah, I know what you mean. I pressurized the interior and I found leaks everywhere. From the door to the tailgate, and the rear window. I think that you're right about the recirculation system. Man it sucks tho', my cargo get dusted with fine dust.
Old 10-13-2004, 09:22 PM
ANdrewdrice's Avatar
ANdrewdrice ANdrewdrice is offline
ANdrewdrice is starting off with a positive reputation.
well, seeing as how we all live on a planet composed of "dirt" I dont think you can solve the problem. no car or truck will ever be able to keep dust out, its just the way of things. I live in the southwest and no way in (you know where) will I ever be able to stop it, especially if I go four wheeling. just keep a cali cleaner or like a swiffer cloth in your rig, and wipe it down every once and again.
EDIT: after reading this I found I came off as kind of a "A" hole, so not to offend anybody, I was just telling the truth.
Old 10-13-2004, 11:06 PM
genueix's Avatar
genueix genueix is offline
genueix is starting off with a positive reputation.
A-hole!
Old 10-14-2004, 06:31 AM
I have had other vehicles that I have used on dusty country roads and have never had a dust problem to the extent I have in my Bronco. However, it is some odd comfort to know that others are experiencing the same frustration.
I bought on of those huge Rubbermaid storage boxes to keep in the cargo area and I put stuff in there that I don't want to get dusty.
Old 10-15-2004, 10:04 AM
raldo_gtm's Avatar
Damn, I kind of knew that the dust would win. I also live in the SW and do alot of backroads driving. I'm going to buy a bag-o-rags and leave it in the Bronco....also some Armor All
Old 10-15-2004, 02:27 PM
armorall attracts dust. it sticks to the greasey residue. I use windex to get rid of dust!
Old 10-15-2004, 02:44 PM
raldo_gtm's Avatar
Yeah, but Windex really don't shine that well. Besides, the dust is gonna get in anyway.
Who's running an Intake? ultrasks700 6.0L Power Stroke Diesel 5 05-24-2016 12:57 PM
Best shock option. dusty trail Fifth Wheel & Gooseneck RV Towing 37 04-21-2016 02:22 PM
Keeping the engine clean. Mikes150 2009 - 2014 F150 11 10-28-2015 07:49 PM
ArmorAll Leaves Dash Discolored NoseDive 2004 - 2008 F150 18 09-07-2006 07:09 PM
Engine power ratings?!? Dustin R Performance & General Engine Building 4 12-31-2002 10:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
