Camper Special Headers - Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
Old 10-11-2004, 08:55 PM
Gunfighter398 Gunfighter398 is offline
Gunfighter398 is starting off with a positive reputation.
Is there a header worthy of installation on a 72 F-250 Camper Special? Thanks
Old 10-12-2004, 04:33 AM
fordloverf2501970's Avatar
fordloverf2501970 fordloverf2501970 is offline
fordloverf2501970 is starting off with a positive reputation.
i think hedman headers part number 87100 is the ones that fit camper special models. at least it is the ones that fit mine
Old 10-12-2004, 08:58 PM
Thanks for the reply. I forgot to say it is a 390 and I have Emailed Hedman and they say theirs doesn't fit the Camper Special with sway braces. Somebody must have one though. Thanks again
Old 10-13-2004, 05:01 PM
are you sure your cs has them ? mine does not have them. then again mine is a 1970 f250 camper special with now a 390
Old 10-14-2004, 07:53 PM
I haven't had it that long, haven't been under it. I'll look. Thanks
Old 10-18-2004, 05:39 PM
nogo73's Avatar
nogo73 nogo73 is offline
nogo73 is starting off with a positive reputation.
try stans-headers(.com) part numbers are for the 2wd is 222y and 4wd is 244y-14. I got there diesel headers and I tell you they got some good welds on them and no leaks. I don't like the chrome but there is no rust on them.
I got pictures in my gallery.
Old 10-19-2004, 12:07 PM
michaelbrainardatwor's Avatar
michaelbrainardatwor michaelbrainardatwor is offline
michaelbrainardatwor is starting off with a positive reputation.
Every header MFG I have found clearly states that the FE block headers they make will not fit camper special trucks or trucks with sway bars....keep searching though. While you are searching...head up my way and help me install my headers! I might start tonight.
Old 10-20-2004, 07:22 PM
again i stress to actullay look under your truck and see if the sway bar is there in the way. i have a all orignal camper special and the sway bar is no where to be found nor is there anything in the way.
1971 f250 camper special headers droptine69 1967 - 1972 F-100 & Larger F-Series Trucks 12 06-19-2015 05:25 PM
1971 F250 15426378 1967 - 1972 F-100 & Larger F-Series Trucks 65 09-02-2014 12:40 AM
headers sniper0587 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 09-14-2012 06:04 PM
knowledge sought claude mccumber jr FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 11-06-2007 03:40 PM
Headers: '78 F250 4WD 40M Camper Special w/sway bar!-Suggestions?? V10man Exhaust Systems 1 08-15-2001 10:46 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1970, 244y, 244y14, camper, f250, ford, headers, special, stans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
