Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-28-2009, 07:56 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
I have seen fuel boil in a float bowl. Or close enough that I didn't want to be around! But, it doesn't make sense to me that you have a fuel bowl filled to specification, and it won't run. The pump obviously filled the bowl, so it is 'out of the picture'.
I had heard of putting clothespins on the fuel line, and have a mental picture of someone going waaayyy over the line, having about 20 pins on about a foot of fuel line.
The ice cubes may have cooled the fuel or fuel pump, but I don't see how it would matter if the float bowl is full.
Putting the choke on will use engine vacuum to pull fuel into the intake, but it should not matter if the carb is working correctly, as the fuel would be pulled into the venturi naturally. This doesn't make sense...
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #17 (permalink)
Old 07-28-2009, 08:31 AM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Perhaps the fuel bowl appers to be full but may be down a 1/16 or so from full, now the pump is getting air not liquid and can't pump. The level in the carb bowl is down or the engine would run. I have never heard of anyone being able to measure the pressure developed when gasoline boils and is evaporated in a line, however since it causes this vapor lock problem it has to be higher than atmospheric pressure, which in fact is what pushes the fuel from the tank to the slight low pressure created at the diaphragm pump. The placement of an electric pump near the tank would be the best cure, but if I would do this a saftey switch on the oil pressure would be a must. I also might put a mercury switch in line to cut it off in case of a roll over. Had a friend who lost his mother because of a lack of an oil switch back in the late 50's she was a great lady. kotzy
  #18 (permalink)
Old 07-29-2009, 08:30 PM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
I have an old Plymouth with a flat head 6, I had the sme issue. Went threw the ignition ect... I re routed the fuel lines, and put in a fuel pump back by the tank... WHat a difference, and problem solved
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis
http://www.youtube.com/watch?v=pibt-TVgAx4
41 Plymouth 49 dodge flathead6 elec ign.
Sig Sauer P229 Two tone.
  #19 (permalink)
Old 08-16-2009, 09:18 PM
'49 F3's Avatar
'49 F3 '49 F3 is offline
'49 F3 is starting off with a positive reputation.
Got 6 volt pump and low pressure regulator from Speedway Motors. Problem solved. Runs all day in 90+ degree weather, now. I don't know why my mechanical pump couldn't keep up with demand under hard acceleration. Maybe float level is too low but electric pump provides higher pressure/volume. Great discussion!
  #20 (permalink)
Old 08-16-2009, 10:38 PM
My viewpoint is that the regulation pump is at the HOT end of the fuel system. Put a pump back at the COLD end, and you won't have any more problems. Exactly what, I will leave to the gurus... I don't claim such sainthood for myself.
tom
__________________
Tags
1950 , 1969 , air , cleaner , clothes , coil , f100 , failures , ford , fuel , line , lock , mercury , pin , quits , truck , vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
