1997 F-150 ABS Light and Brake Light - Ford Truck Enthusiasts Forums
Old 10-10-2004, 08:57 PM
beene17 beene17 is offline
beene17 is starting off with a positive reputation.
Hi. I have a '97 F-150 4.2L 4X2 with a manual trans. It has about 49,000 miles on it. The ABS light is on as well as a the Brake light which is on slightly. I saw a post from 2002 that touched on this but I did not see a reply. Any idea what this is? The book said if the brake light is on that brake fluid may be low. I checked that and did find it to be slightly low but nothing major. I added some fluid but the lights are still on. Any help would be great so I don't have to take it in and have it scanned.
Thanks!
Old 10-11-2004, 05:00 PM
BigRedLongbed BigRedLongbed is offline
BigRedLongbed is starting off with a positive reputation.
This happened to me. I had to replace the brake pressure switch, which i got from a wrecked f-150. after i replaced that, my abs light turned of and all was well. Im not sure if you have the same problem that i had, when it happened to me my brake lights wouldn't turn on when i hit the brakes. but its worth a try. Only cost me around $20.
Old 10-13-2004, 07:41 PM
Thanks for the help! I'll check into it and post back. I believe my brake lights are working (at least I haven't been run into or pulled over yet!) but I will check them. I have also heard from friends that it could be the ABS sensor in the rear differential or possibly the whole ABS unit.
Thanks again!
Old 10-13-2004, 07:57 PM
Smaug's Avatar
Smaug Smaug is offline
Smaug is starting off with a positive reputation.
you can get it scanned for free at Auto Zone
Old 10-14-2004, 09:14 PM
canucker canucker is offline
canucker is starting off with a positive reputation.
I was in the same situation.Here's what I replaced.......first i replaced rear abs sensor.....then i replaced the abs module....then i replaced the abs valve(under the brake cylinder).If its the abs module, go on ebay cause a guy was selling them for 9.99 each and i paid $100. The abs valve i got off a 97' from the junkyard for $75 (canadian) because dealership wanted $400.
Old 10-15-2004, 06:26 PM
98 4.6 locked up 98 4.6 locked up is offline
98 4.6 locked up is starting off with a positive reputation.
I don't think autozone can scan abs codes. I had the sane problem on my 98 and the problem was the abs solenoid under the brake reservior. It could also be the abs module under the dash or the abs sensor on rear diff like was said earlier in post. To pull abs codes you have to ground a wire behind pass kick panel. Pretty easy to do. I think it is a brown wire with stripe but not positive. If you need, I can check.
Old 10-17-2004, 05:24 AM
F150ownz F150ownz is offline
F150ownz is starting off with a positive reputation.
sounds like rear wheel speed sensor... mine went out at about 95,000 miles had same symptoms except my speedo didnt work... but could be ABS sensor also
Brake fade/soft pedal--rabs bypass repair 92 F-250 chipper Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 10-01-2016 03:45 PM
94 F-150 4x4 No rear brakes M3talz 1987 - 1996 F150 & Larger F-Series Trucks 12 09-08-2015 01:05 AM
1981 F150 1/2 ton parking brake light stuck on Floggit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 03-29-2015 02:14 PM
1991 E150 ABS Hydraulic Unit freevan 1968-2013 Full Size Vans 0 09-09-2014 02:55 AM
2004 F150 ABS Issue Riskyguy 2004 - 2008 F150 2 07-20-2014 01:49 PM
Tags
97, abs, f150, light, problems, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
