Whacky idle then quit w/no spark - Ford Truck Enthusiasts Forums
Old 10-10-2004, 01:14 PM
shmady shmady is offline
shmady is starting off with a positive reputation.
Hi, OK here's the deal.. 88 Ranger 2.3 5sp Fuel Inj. no AC. Pretty much stock everything. Lately, the idle has been high after warm up, other words the idle seemed to stay high between gears like speed shifting without the gas pedal pushed (Fun... but NOT NORMAL) also at a stop with clutch in or in neutral it would take a while to idle down. This has been occuring on and off for a few weeks now. The "Whacky" part is the other morning the truck just flat quit running on the way to work. Got juice, Cranks good, got lights ect. fuel pump relay and fuel pump sound normal. Checked for spark at plugs and coil by cranking and looking for spark....got nuttin' hunny. I realize I may have two seperate problems..maybe not. Been a good runner for many years with regular tune ups, oil changes ect. My question is ..Where do I start, to avoid needless parts replacement and wasted brain power? Sumbuddy peez hep me.
Old 10-13-2004, 09:11 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
The expert answers to your questions would come from the guys on the Ranger board:
http://www.ford-trucks.com/forums/forum35/
Click the link to go directly there.
AL.
Old 10-16-2004, 05:15 PM
Found the prob.....BUSTED TIMING BELT...that'll take away yer spark Ay?....DUhhh. Anyway, got a new belt..installed it by the book (timing marks lined up, dist rotor pointing to #1 ect.) Starts rite up, idles good, but now its sluggish on acceleration. Do I need to time the ignition with a timing light? or is there something else to consider...once again peez hep me....thanks.
Old 10-16-2004, 10:40 PM
Dealford's Avatar
You should at least check to see where the timing is set at. From there, you can try to bump it up a little to see how it likes it.
AL.
Bang your heads for the 6.0 nightmare David7.3 6.0L Power Stroke Diesel 45 09-12-2015 01:05 PM
1994 F-150 5.0L MISSES BADLY under Accel from lower RPM - FIXED!! SitkaSpruceMica 1987 - 1996 F150 & Larger F-Series Trucks 7 11-15-2013 05:29 PM
Intermittent idle? fenix1 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 01-27-2013 06:42 PM
Got a possible good question for us to discuss 94 smokin stroker Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 01-20-2011 06:14 PM
Loosing spark 89 4.9 fast_st 1987 - 1996 F150 & Larger F-Series Trucks 0 02-19-2009 10:07 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
