Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > West Virginia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: msgtg
  #1 (permalink)
Old 10-09-2004, 08:57 AM
Hillbilly48 Hillbilly48 is offline
Garage is empty, add now
Hillbilly48 is starting off with a positive reputation.
Explorer 96
My wipers, door locks and domelights are going out intermitently, sometimes for days then come back. Any suggestions?
  #2 (permalink)
Old 10-11-2004, 04:20 AM
fitter565's Avatar
fitter565 fitter565 is offline
fitter565 is starting off with a positive reputation.
Hillbilly48, Welcome to the WV chapter! I would look for a loose ground. Then I would trace down each wire looking for broken or bare wires. I'm sure someone will chime in soon with some other idea's.
Mike
__________________
2005 Explorer Sport Trac XLT Premium
2002 Escape XLT 4x4 3.0 v6 (Wifes ride)
Support FTE
  #3 (permalink)
Old 10-11-2004, 10:48 AM
5_labsownus's Avatar
5_labsownus 5_labsownus is offline
1999 Ford F-250
5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.5_labsownus has a good reputation on FTE.
You may need to get into the dash. Most trucks have the wiring harness for all options and the pigtails for the options are not installed on vehicles that do not have them (electric door locks). The plug where the pigtail and harness meet may not be together good! I have had this happen before even with the locking type plugs. Also you may need to pull the plugs apart and make sure the pins are push into the plug and lock in place. All of the non-water proof plugs (mostly under the dash) have removable/replaceable pins. Some times the pins will push out when the plug is put together.
If this is not the case I would look at the ground as Mike said.
If the Dome lights are electronic controled i.e. auto shut off, auto dim, or turn off when engine is started. The control module may be bad or loose. Many times these modules control many systems and could include the wipers, lights and other alarms!
__________________
Toby Wan-Knobey
WV Chapter Member
This is my RCA dog look!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
