Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-08-2004, 10:52 PM
fordnut74 fordnut74 is offline
Garage is empty, add now
fordnut74 is starting off with a positive reputation.
Any market for filtered VEG OIL as a supplement?
Just wondering if there is anyone that would be interested in buying Filtered Vegetable Oil as a suplement for around $0.75 a gallon keeping in mind that you can use it in up to 50% ratio with no adverse effects or modifications to the motor or fuel system. I am considering whether or not I could help some people lower there fuel bill. And do my part to take some power away from stinkin' OPEC. For as little as an extra $50 you could run up to 80-90% oil depending on your local climate. Anyway, any interest?
__________________
99 SD PSD, CC, SB, 4X4, Phantom gages, bypassed wastegate, a/p regulator to avoid defuleing, Home made SVO kit, Edge Evolution, 6637 air filter, straight piped exh, 15.2@86 1/4 mile
  #2 (permalink)
Old 10-08-2004, 11:12 PM
broken wire broken wire is offline
broken wire is starting off with a positive reputation.
Is this oil fresh pressed from the seed, or is it vegetable oil filtered after going through the cooking stage?, Vegetable oil straight new press in excess of 5% is not allowed (except for our government to use, LOL) it goes outside the limits of astm standards of diesel fuel, Vegetable oil has a bunch of great benefits, raises cetane number, lubricity, helps knock down carbon deposits, cancer causing problems go down, black smoke leaves, blue haze comes in, smell like hamburgers, engine does not knock as loud. Used oil I am not aware of where you are allowed to go in percentages, except for the apperatus of Greasel, and I only know them by there name. Just commenting.
  #3 (permalink)
Old 10-08-2004, 11:14 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Quote:
Yes, but this needs to be taken off line. Check your PM's.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #4 (permalink)
Old 10-09-2004, 01:31 PM
DOH!, Yeah I wasn't even thinking about the implications, my bad. If I could edit, I would rephrase things a bit.
Stranded wire, this is used waste oil collected from local restaraunts and stores. I have made my own WVO kit, and run it very succesfully in my truck. .I have done quite a bit of experimenting with running it in varying %'s, heated and unheated, and have learned what I can get away with using a stock filter, or aftermarket filter. Been a bit painful at times, but well worth it. I don't believe there is a current federal limit on how much "additive" you can add.
__________________
  #5 (permalink)
Old 10-10-2004, 09:22 AM
tcdfwilson tcdfwilson is offline
tcdfwilson is starting off with a positive reputation.
I am very interested in the kit for using vegetable oil. Let me know some more details.
__________________
1997 F250 PSD, CrewCab, 195K miles
  #6 (permalink)
Old 10-10-2004, 09:47 AM
1999 Ford F-550
Here's some useful web sites. http://www.greasel.com/ www.biodiesel.com.
Also there are forums both here (I think) and at dieselstop for alternative fuels.
I was up at Fordnut74's house yesterday and was impressed with the amount of work that he has done to convert his PSD over to SVO. Nice truck too by the way. He told me he has put about 4 months worth of driving so far on the SVO with no problems other than several clogged fuel filters before he figured out how to properly heat the fuel on board the truck.
Gathering the fuel is going to cost you some time and energy. It has to be strained and filtered before you even pour it into the fuel tank on your truck. Space must be made on your property to do all this requiring several barrels and rather large filter housings, pumps, etc. Apartment/condo dwellers need not apply.
__________________
Dan
  #7 (permalink)
Old 10-10-2004, 11:59 AM
Thanks Kwik, certainly has been an interesting trip. Did some troubleshooting last night and I am pretty sure i have a bad fuel pump. I did some research on the bosch pumps like you suggested, and wound up ordering a bosch # 0-580-254-984 from Schucks in their MASTER equivalent for $116. it has essentially a 1/2" inlet and outlet, rated to flow 55gph, and max pressure of 150psi, nominal of like 75. It is a stock replacement for a 1980 mercedes 280E, with a carburated 2.8l. Why that car needs that pump
TCDFWILSON, another very informational, but little knopwn site is http://www.vegburner.co.uk/votheory.htm . Explains more than you will ever need to know about veg oil theory, properties and etc.
__________________
  #8 (permalink)
Old 10-10-2004, 12:21 PM
1999 Ford F-550
That is indeed a lot of fuel pump for a carburated car. You'll like the Bosch. Top quality stuff. Lasts for years.
__________________
Dan
  #9 (permalink)
Old 10-10-2004, 11:31 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
That pump might be too small. The factory Bosch pump on your truck will flow ~75 GPH at 0 PSI, but at 50 PSI it'll pump less than 30 GPH.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #10 (permalink)
Old 10-10-2004, 11:38 PM
1999 Ford F-550
Quote:
That's not enough? Cookie I am just a simple mechanic but it seems to me that that's a lot of fuel for the engine to play with.
__________________
Dan
  #11 (permalink)
Old 10-10-2004, 11:47 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
Quote:
No, no....that's gobs of fuel. I simply meant that the pump that fordnut selected potentially flows less than the factory pump. Bosch # 0-580-464-074 is the factory pump.
__________________
Scott
  #12 (permalink)
Old 10-10-2004, 11:51 PM
1999 Ford F-550
Ok, learn a new thing every day. Thanks for the info.
__________________
Dan
  #13 (permalink)
Old 10-11-2004, 12:15 AM
Given my luck, that wouldn't surprise me, but I have to doubt it, maybe because of all the work I went through to install it. but here are the numbers for the bosch, and some other popular pumps. After looking at the stock pump, I don't see how it can flow 75 gallons/hour. I was looking in the oulet side, and with the fitting removed, it bottlenecks down to at least an 1/8", if not smaller. Either way, I just posted my test results in another thread, and life is good. For the time being
__________________
  #14 (permalink)
Old 10-11-2004, 12:35 AM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
I think it's 3/16". Is the inlet screen in the pump plugged, or have you determined the source of the pump failure? Your stock pump should have been flowing about 20 times what you found in your test.
Are you running any type of pre-pump filter, other than the stock 200 micron screens in the mixing chamber and pump inlet?
It sounds like you have quite a set-up for your WVO, how finely are you filtering it before you put it in the tank.
__________________
Scott
  #15 (permalink)
Old 10-12-2004, 07:00 AM
Cookie come to find out, you were right on most counts Thanks for being there too late . Just kiddin I continued the pump stuff on my "replaced fuel pump, all is right in the world " thread
For my final filtering stage I pump it through a baldwin P555823 fuel filter that I get from the local Peterbuilt shop. That is the exact same filter I have on my truck, so I know if the oil passes through it once, it will do it again.
__________________
Tags
074, 464, 580, bosch, buying, filered, ford, fuel, oil, trucks, vege, vegetable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
