Ignition Key Chime
Old 10-07-2004, 08:14 PM
nhood's Avatar
nhood
nhood is offline
Ignition Key Chime
I am new to the Forum and I have a question about the ignition key chime.
Even if the key has been removed from the switch,the chime sounds as long as the door is open.
My question: Is there any way to disable this chime?
Thanks for listening.
Nigel Hood, Louisville,Ky
Old 10-07-2004, 09:52 PM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
You didn't say what year your truck is. on the older 93-97 models you can just pull the harness off the chime. It is under the dash just left of center, right above the tranny hump in the floor. the easiest way to find the chime is to open the door, lay on your back on the drivers floor and start listening. once found, pull the wiring harness off it. this will also solve the lights left on chime, which could be a bad thing, but I still did it to mine.
Diesel rod
Old 10-08-2004, 12:37 AM
89ford73's Avatar
89ford73
89ford73 is offline
the 99's up are a bitch, my buddy got so mad at his one day that he started cutting wires till it quit. his ac. power windows, and interior lights went out. but he claims he was happy....???¿¿ i dont know bout that boy sometimes. he fixed the ac and the windows. but not the interior lights does anyone know how to do it to a 99-up w/o being distructive?
Old 10-08-2004, 08:04 AM
mueckster's Avatar
mueckster
mueckster is offline
Without access to a wiring schematic for the chime box (have one for a '91), you could release the wires from the chime plug and reconnect them to the chime. Then remove them one at a time until you find the one that triggers it with key in the lock cylinder.
Old 10-09-2004, 04:18 AM
nhood's Avatar
nhood
nhood is offline
Thanks for the help. The year is 1997 250 p/s. Took 30 sec. to find the black noise maker. Disconnected the wires and no noise !!!!! Thanks again. nhood
bigcountry1009
1999 to 2016 Super Duty
11-13-2014 08:07 AM
Nigel1100
New Member Introductions
05-29-2014 03:04 PM
SideWinder4.9l
Kentucky Chapter
09-11-2013 11:53 AM
Hotest Rod
Electrical Systems/Wiring
02-19-2003 12:31 AM
Quick Reply: Ignition Key Chime
