ABS sensor location for 2002 explorer - Ford Truck Enthusiasts Forums
Old 10-07-2004, 09:27 AM
dbessey dbessey is offline
dbessey is starting off with a positive reputation.
Question ABS sensor location for 2002 explorer
Greetings:
I have a 2002 Explorer. The ABS light is on. I have tracked down the location of the front wheel sensors, but can not locate the sensor(s) for the rear wheels. Can anyone tell me where to find the rear wheel sensors?
Thanks
Darren
Old 10-08-2004, 02:28 PM
Guido492 Guido492 is offline
Guido492 is starting off with a positive reputation.
I'd like to know myself. My light came on about 2 weeks ago but I haven't had a chance to get in and find any of them yet. Gonna try to replace it tonight.
Old 10-09-2004, 06:53 PM
ArkieRebel ArkieRebel is offline
ArkieRebel is starting off with a positive reputation.
It's on top of the rear end housing. Should have a two pin connector. It's the only electrical connection on top of the differential housing.
Old 10-09-2004, 11:29 PM
'99 black sport '99 black sport is offline
'99 black sport is starting off with a positive reputation.
Usually that sensor goes bad before the others. Easy to replace,but may be stuck in the housing pretty good. Use some petroleum jelly and coat the o-ring of the new sensor before install. All the speed sensors should read no more than 3-4 mph apart. If they read more than that, it will set a light and a code.
abs sensor potseroller Brakes, Steering, Suspension, Tires, & Wheels 0 09-08-2013 06:12 PM
98 Explorer Sport Oxygen Sensor Location perforster Explorer, Sport Trac, Mountaineer & Aviator 2 02-27-2007 10:36 PM
4 wheel ABS vs. RABS on '97 Ranger 2WD handrail Ranger & B-Series 5 12-07-2005 09:27 PM
ABS Sensors on 2002 Explorer Bob Ayers Explorer, Sport Trac, Mountaineer & Aviator 19 08-23-2005 10:21 PM
2002 Ford Explorer Sport Trac headlight photo sensor location micpat Explorer, Sport Trac, Mountaineer & Aviator 2 10-08-2002 09:51 PM
Tags
02, 2002, abs, antilock, differential, explorer, ford, install, light, located, mountaineer, rear, replace, sensor, sensors, whell
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
