99 Explorer O2 Sensor failed
Hi all..
I have a 99 ford explorer 4D, 4WD V6.
I have a Check engin light on that is reporting code 171 - O2 Sensor - Bank 1 is reading to lean..
Can someone point me to where this is located on the truck? The Bank one leads me to believe that there are more than one and I would rather not drop the $60 more than I need to
Thanks for the help
Thanks for the help
Originally Posted by Pig Pen Jr
When I replaced the ones on my '99 XLT there were 4. One on the exhaust pipe before the cat and one after the cat on each side. They look like spark-plugs that are screwed into your exhaust system.
Thanks for the reply.... Appreicate the help
# of O2 sensors
I believe that all Explorers thru '99 have 4 sensors. On my '96 with a V6, sensor #1 is located on the passenger side exhaust manifold about halfway between the exhaust header and the converter. Best access is through the wheel well by removing the inner fender skirt. I thought only Rangers with the 2.3L had two sensors?
I will find out for sure tomorrow when I get down underneath it and see it for my self..
Hopefully the AutoZone guys know what they are talking about..
Luckilly that sensor wasn't all that bad so I can change it to the other side if needed..
99powerstrokedF250
08-16-2015 02:51 PM
albtrossca
1997-2006 Expedition & Navigator
04-19-2013 10:45 AM
breeaad
07-10-2012 09:02 AM
Redneck1465
11-04-2009 10:00 AM
