99 Explorer O2 Sensor failed - Ford Truck Enthusiasts Forums
Old 10-06-2004, 12:02 PM
stunod2002's Avatar
stunod2002 stunod2002 is offline
stunod2002 is starting off with a positive reputation.
Question 99 Explorer O2 Sensor failed
Hi all..
I have a 99 ford explorer 4D, 4WD V6.
I have a Check engin light on that is reporting code 171 - O2 Sensor - Bank 1 is reading to lean..
Can someone point me to where this is located on the truck? The Bank one leads me to believe that there are more than one and I would rather not drop the $60 more than I need to
Thanks for the help
Old 10-06-2004, 03:17 PM
Pig Pen Jr's Avatar
Pig Pen Jr Pig Pen Jr is offline
Pig Pen Jr is starting off with a positive reputation.
When I replaced the ones on my '99 XLT there were 4. One on the exhaust pipe before the cat and one after the cat on each side. They look like spark-plugs that are screwed into your exhaust system.
Old 10-06-2004, 03:31 PM
stunod2002's Avatar
Quote:
I just got off hte horn with my local shop.. They told me that Bank 1 is right before the CAT... But I only have 2, not 4
Thanks for the reply.... Appreicate the help
Old 10-08-2004, 08:24 AM
ajguzik ajguzik is offline
ajguzik is starting off with a positive reputation.
# of O2 sensors
I believe that all Explorers thru '99 have 4 sensors. On my '96 with a V6, sensor #1 is located on the passenger side exhaust manifold about halfway between the exhaust header and the converter. Best access is through the wheel well by removing the inner fender skirt. I thought only Rangers with the 2.3L had two sensors?
Old 10-08-2004, 08:31 AM
stunod2002's Avatar
Quote:
I really have no clue.. I am at this point believing the ford guy, after all he should know
I will find out for sure tomorrow when I get down underneath it and see it for my self..
Old 10-08-2004, 09:01 AM
Pig Pen Jr's Avatar
He probably has the standard 4.0 and not the 4.0 SOHC. That is the only differance I can see it being.
Old 10-08-2004, 09:27 AM
stunod2002's Avatar
Not sure.. I will have to check
Old 10-09-2004, 12:12 PM
stunod2002's Avatar
Quote:
I actually have the SOHC 4.0
Old 10-09-2004, 02:22 PM
stunod2002's Avatar
Well There is infact 4 sensors.. I could not find anything that specifically said what Bank #1 was, however the wonderful techs at AutoZone said that it was the driver side.. SoI gave that a shot.. I cleared error code so not its a wait and see..
Hopefully the AutoZone guys know what they are talking about..
Luckilly that sensor wasn't all that bad so I can change it to the other side if needed..
Old 10-09-2004, 11:17 PM
'99 black sport '99 black sport is offline
'99 black sport is starting off with a positive reputation.
I have the ohv standard 4.0, not the sohc.......they all have 4 o2 sensors. banks1 and 2 are before the cats....banks 3 and 4 are after.
5.4 in a 2005 e-150 wtroger Modular V8 (4.6L, 5.4L) 10 10-21-2015 04:01 PM
P0059 and P0152, O2 sensor 99powerstrokedF250 2007 - 2014 Expedition & Navigator 0 08-16-2015 03:51 PM
O2 sensor bank one pnp522 Modular V8 (4.6L, 5.4L) 3 07-15-2015 05:40 PM
2000 F150 4wd 5.4 Running full rich gixxer.taylor 1997 - 2003 F150 10 06-02-2015 12:24 AM
HO2 - Bank 1 Faulty Sensor? gaviotas Explorer, Sport Trac, Mountaineer & Aviator 2 02-04-2004 10:44 AM
Tags
99, bank, change, code, explorer, explorere, failure, ford, located, locations, o2, oxegen, replace, sensor, sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
