1962 Ford F-602 Timing - Ford Truck Enthusiasts Forums
Old 10-06-2004, 09:53 AM
Sam Smanko Sam Smanko is offline
Sam Smanko is starting off with a positive reputation.
Does anyone know the timing of a "Q" engine. I think it is a engine; or if not, do you know if it is covered in the sevice manual? That is to ask, is it worth my spending $75 to buy a manual only to find that it either is not in the manual or that it is something that someone here can tell me? Tks.
Old 10-06-2004, 10:36 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
I'm going to guess you have a 292. A V-8 where the driver side exhaust comes out the front and crosses to the passenger side manifold?
I'm going to guess again. Try 6 degrees btdc. Regular fuel 289's & FE's were at 6 degrees, so I'm guessing Ford liked that number. You might be able to run up to 10, but start at 6 and see how it runs.
Still have points? .16 I think. Am I right? Is my memory still there?
Better minds may chime in.
ID that motor and try the motor specific threads if you have no luck.
Old 10-06-2004, 05:18 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
That engine could also be a 330 or a 361.
Old 10-06-2004, 07:39 PM
Kenny's Avatar
Kenny Kenny is offline
Kenny is gaining momentum as a positive member of FTE.Kenny is gaining momentum as a positive member of FTE.
Hi Sam,
Engine code "Q" would be the 477 Super duty V-8 engine.
According to my '59 Truck shop manual...............
"Initial Ignition Timing (B.T.D.C.)"
"All HD and SD V-8 (302,332,401,477,534)
With regular fuel of 85-88 octane..........................................4 Deg.
With regular fuel of 88-90 octane..........................................6 Deg.
With regular fuel of 90-92 octane..........................................8 Deg.
With regular fuel of 92 octane or more, or premium fuel............10 Deg."
I hope this helps.
7.3L Diesel Engine Supplement owners manual. stloupster Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 26 01-15-2016 05:22 PM
The 1980 F100 4x4 inline 6.247 diesel WOrkshop Manual DedmonDuppy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-10-2015 01:54 AM
Repair manual help elroy6468 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-28-2015 11:55 PM
Manual Transmissions in 2014+ texastech_diesel 1999 to 2016 Super Duty 283 03-26-2015 12:18 PM
timing 1985 f-700 tree medics Large Truck 0 11-25-2011 04:26 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1962, 401, 602, adjust, brake, engine, f602, f602d, ford, fsuperduty, sale, timing, timming, truck, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
