302 roller cam
302 roller cam
Over the last couple of days I have been putting my long block together. It is going from a stock 302 to a wild 347 stroker. I'm putting in a roller cam with the roller lifters. Do you have to break in a roller cam the same way as a stock non-roller cam.
As an afterthought, I wouldn't mind hearing some estimates on horse power, if any cares to guess. Here's the setup:
Balanced 347 with World Roush 200 heads 2.02 int/1.6exh, flat top pistons
Lunati roller cam 290/300 .540/.560 lift, roller lifters, roller rockers
MSD ignition, coil, 6A box
Holley 670 street avenger
Edelbrock PRPM dual plane
Dynomax headers, dual exhaust, 40 series flowmasters
Nearest I can figure is that it's going to be alot. Thanks
Sanders
Sanders
