How many 68-74 Econoline vanners out there? - Page 3 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
  #31
Old 08-12-2012, 01:44 PM
95e150CW 95e150CW is offline
95e150CW is gaining momentum as a positive member of FTE.
Same thing with 1998 Super Duty pickups. There are no 1998 F350s. Ford just made the OBS until they ran out of parts, then started making the 99 F350 as early as march of 98. This same time period results in the 'F250 light duty'. F250 chassis with F150 body and some abomination 7 lug axles.
  #32
Old 08-13-2012, 08:28 PM
maples01's Avatar
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
I have a 73 E-100 LWB with a 302 and automatic transmission, I got all the paperwork with it, love the van, they are an odd ball, the engine is shifted toward the passenger side, rather than center, leading to the off center van specific rear axle, much like the Jeep Wagoneer, and Suzuki Samari.
  #33
Old 08-13-2012, 11:04 PM
Club Wagon Club Wagon is offline
Club Wagon is gaining momentum as a positive member of FTE.
Note that "the engine is shifted toward the passenger side" on every Econoline built since this series began.
Quote:
This was covered at some length previously.
  #34
Old 08-14-2012, 03:21 AM
maples01's Avatar
It's far more noticeable in the mid Fords, that's why I brought it up!
Also, I mentioned the rear axle too, the later models aren't the same.
  #35
Old 08-14-2012, 10:27 AM
Later Econolines models also all have "off center van specific rear axle".
IMO it's just as "noticeable" on "the later models". As mentioned in previous "off center" discussion it's common, not "odd ball". In terms of 3 versions of Econoline having motor, drive shaft & diffy "shifted to the passenger side" they are "the same".
  #36
Old 08-14-2012, 04:39 PM
maples01's Avatar
  #37
Old 08-18-2012, 09:33 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
False......... 75and up vans don't have the rear diff off set like the earlier models. The only reason they are van specific rear axles, is the width of the spring spacing. But if you move some spring perches around a bit, you can run the van axle in a pickup, and the pickup axle in a van no problem.
  #38
Old 08-18-2012, 08:05 PM
maples01's Avatar
Don't argue with him!
  #39
Old 08-18-2012, 09:17 PM
hav24wheel's Avatar
I know my Ford parts, I have bolted stuff together that most figure wound never go. I've spent my fair share o time under various Fords.
Offset or not?
  #40
Old 08-18-2012, 09:24 PM
hav24wheel, in this case maples01 appears to have offered you excellent advice. However feel free to "argue" w/all the contributors & photos on the previous thread if you like.
http://www.ford-trucks.com/forums/11...ter-75-on.html
Quote:
Anyone care to chime in on widths of Econoline van & F-Series pickup rear axles to help hav24wheel discover what is "False"? Perhaps a new thread can "argue" IF "you can run the van axle in a pickup, and the pickup axle in a van no problem"?
  #41
Old 08-18-2012, 09:30 PM
Then again we could just cut to the chase:
On the 68-74 body style vans, they even had the pumpin on the rear diff offset to the passenger side. It's not as noticeable in my 79 as it was my old 74.
  #42
Old 08-18-2012, 10:50 PM
hav24wheel's Avatar
Ever look at other rigs? EB Broncos engines where set to the passenger side too, but just because the engine is set to the side doesn't mean the diff pumpkin is set to the side more than a pickup, or any other vehicle. If you look at the pinion where it sits on the diff, almost 100% of axles have it set to one side vs dead center.
As for axle interchange between Econolines and F series, anything is possible. My 79 has front and rear axles out of a 92 F350, I have a pickup that has a 74 clubwagon Axle under it. Ive also bolted front pickup axles in place of van axles. No mods needed.
  #43
Old 08-18-2012, 11:15 PM
Off center is off center.
Take "they are an odd ball, the engine is shifted toward the passenger side, rather than center, leading to the off center van specific rear axle" up w/maples01.
Or "argue" w/yourself "the pumpin on the rear diff offset".
Its not a Q of how "noticeable" or "more" off center. They're either centered or they're not.
  #44
Old 08-18-2012, 11:53 PM
maples01's Avatar
Mighty damn funny how when I had my axle shafts out and they were the same length, perhaps I can't tell the difference with them standing up side by side maybe?
  #45
Old 08-18-2012, 11:55 PM
hav24wheel's Avatar
Pumpkin could be centered wild the pinion is off set. The pinion could be centered with a off set pumpin.
I'll take a tape to some axles tomorrow and see what comes up.
Any '68-'74 Econoline folks here?? Supercab 1968-2013 Full Size Vans 28 04-30-2016 02:22 AM
68-74 Econoline Tires 6874 1968-2013 Full Size Vans 10 06-16-2015 07:01 PM
68-74 Econoline pop-out window seal (outer) piperguy1 1968-2013 Full Size Vans 4 12-06-2014 09:00 PM
1977 F-250 4x4 Build oldmx 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-15-2014 10:14 PM
Takin it EZ site?? Supercab 1968-2013 Full Size Vans 2 01-27-2010 12:42 AM
Tags
1968, 1972, 68, 72, 74, chateau, e200, econoline, econolinesipbhostcom, ford, gas, mileage, specs, van, wagon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
