differences in 355 vs 373 rear? - Ford Truck Enthusiasts Forums
Old 10-05-2004, 09:13 PM
fanfare fanfare is offline
fanfare is starting off with a positive reputation.
I got the 355 rear end ... I was wondering if anyone tows with this ratio. Because I don't plan on towing more than 7000 lbs I figured I would try to get better MPG under highway conditions (not when I'm towing of course) and was wondering if those who have 355's are happy with them. The dealership I bought from says he mostly gets 355's now (he may have gotten more 373's on earlier shipments) Can't seem to figure out why his later build inventory is mostly 355. He says he orders 355's now ... but who knows what the real rason may be.
Old 10-05-2004, 10:11 PM
FX4dude FX4dude is offline
FX4dude is starting off with a positive reputation.
I don't have a 3.55 but I like to tell all of you what happened to me regarding this choice.
I wanted to order my truck with a 3.55 because I thought it would get better gas mileage and have lower RPM's while crusing on the highway.
To make a long story short, I had to take the 3.73 when I purchased my truck. Now, I'm glad I got the 3.73.
Highway crusing with 3.73: The stock truck cruised under 2,000 RPM. Great!
Gas mileage comparision between the 2 rearends: I don't know? The number might be small. Driving habits may affect gas mileage more.
Ok, on to the good news. I have taller tires now and the 3.73 is quicker off-the-line than the 3.55. I have heard of some guys wanting to re-gear their rearends to 4.10's or higher after a lift and tire change.
I think my truck is great with a 3.73 rear, 315/70/17 tires, and a Superchips programer.
Just my 2 cents.
Old 10-05-2004, 10:19 PM
DirtyDiesel DirtyDiesel is offline
DirtyDiesel is starting off with a positive reputation.
i am in thwe market for a 04 150 and this is good to know thanks
Old 10-05-2004, 10:50 PM
bigdavewilson bigdavewilson is offline
bigdavewilson is starting off with a positive reputation.
Gear ratio
Quote:
My 02 with 5.4 had the 3.73 rear end and I did use it a bit for towing a relatively heavy trailer. Seems to me most of the time I locked out the O/D anyway. My 04 has the 3.55 with 265/17 tires replacing the factory 255/17's.Although I haven't towed anything bigger than a 14' boat my guess is that the new truck would be better overall in that it runs at lower rpm with O/D locked out. The new 3 valve motor does seem appreciably stronger and it gets better fuel economy by about 10 to 15%. I'm more that happy with the 3.55's (which because of the bigger tires is more like 3.50).
Old 10-06-2004, 03:11 AM
Birdhunter1's Avatar
Birdhunter1 Birdhunter1 is offline
Birdhunter1 is gaining momentum as a positive member of FTE.
Quote:
What kind of speed are you rrunning, 70-80 mph?
On my 3.55 rear with a 4.6 engine I can run 80 at just a hair under 2000 rpm's. 55-60 is the sweet spot for gas mileage though. 70 mph is about 1800 rpms.
Old 10-06-2004, 07:42 AM
scottb1014's Avatar
scottb1014 scottb1014 is offline
scottb1014 is starting off with a positive reputation.
I have 3.55 now, and will be upgrading to 4.10 once my suspension lift goes on next week. I also have 315/70/17's on there now.
Just with a leveling kit and the bigger tires, my get up and go is less than desirable. So im looking for best deal to do gears after my lift goes on.
Old 10-06-2004, 12:14 PM
dentexman dentexman is offline
dentexman is starting off with a positive reputation.
FANFARE, I have a Lariat SCrew with the 3.55. I towed my 4,000 lb. camping trailer with five of us in the cab and five bicycles in the bed to Yellowstone this summer (from TX). It towed fine. I turn OFF the overdrive unless I have a tailwind and level or downsloping terrain. I averaged about 11 MPG and used the air conditioning occasionally.
Old 10-06-2004, 07:02 PM
I believe it was 75 MPH.
4.10 vs 3.73 vs 3.55 fireball318 Modular V10 (6.8l) 6 06-04-2013 06:10 PM
3.55 or 3.73 Reaver75 5.0L Coyote 7 03-20-2011 02:19 PM
3.55 vs 3.73 svt2205 2009 - 2014 F150 11 03-23-2010 02:22 PM
3.55 or 3.73? bass3006 2004 - 2008 F150 13 02-27-2010 11:45 AM
355 vs 373 Ltd. Slip Differential aromandoj 2004 - 2008 F150 6 08-13-2004 01:02 PM
Tags
355, 373, axle, compared, differential, end, f150, ford, liter, mpg, rear, review, slip, stock, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
