Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-31-2001, 11:11 PM
babybroncoii babybroncoii is offline
babybroncoii is starting off with a positive reputation.
air conditioning
i just found out today that i need to replace the discharge hose for my air conditioning because of a leak on my 88 bronco ii. i have already leaked out the r-12, but i am looking to convert the system to r-134a. i have already bought a kit and it comes with the cans and the oil to do it. the problem is that it says to flush out the system with an air compressor. i have an air compressor but i haven't quite figured out where to hook this up to to run all of the r-12 out of the system. has anyone else done this change from r-12 to r-134a? since i live in arizona where it is a million degrees outside, any help would be greatly appreciated right away. thanks
george
  #2 (permalink)
Old 06-01-2001, 11:25 AM
whomrig whomrig is offline
whomrig is starting off with a positive reputation.
air conditioning
Hi George, this job will require replacing the receiver/drier (this is a must) and doing a vacuum or evacuation on the system with a pump made for this. The system has to be "pumped down" to 30" of merc if possible. It has been 17 years since I have recharged an a/c and I had access to the evac/charging station at that time. Best of luck on your job.
Wayne
e-mail
http://home.pacbell.net/whomrig
__________________
Wayne
2001 F-250 XLT 8' Supercab Longbed 4x4 V10
  #3 (permalink)
Old 06-17-2001, 02:50 AM
air conditioning
just in case anybody wanted to know, i pulled the discharge hose that had a hole in it in my 88 bronco ii, and r12 shot all over the place. i wouldn't recommend it considering it is pretty bad for the environment, but all i did was push r134 into the system along with some of that compressor oil (it all comes in a kit at autozone), and my air works great. i read the instructions in the kit and i was going to replace the drier, but it doesn't say anything about it, and i was so mad at my truck for losing the air conditioning in the first place that i just decided to do it. anyone that is thinking about this conversion, it is really easy. good luck
  #4 (permalink)
Old 06-22-2001, 05:02 PM
Quang Quang is offline
Quang is starting off with a positive reputation.
air conditioning
Did you evacuate the system at all or you just injected in some R134a gas?
Quang
89 Bronco II
  #5 (permalink)
Old 06-25-2001, 01:11 PM
air conditioning
well there was a hole in my discharge hose. i assumed the system was empty and went to replace my discharge hose when r12 sprayed all over me. then i just put on the new hose, filled it up with two cans of r134, a can of the compressor oil, and the rest with r134 and that was it. i didn't flush the system or anything.
  #6 (permalink)
Old 06-26-2001, 06:52 PM
air conditioning
Interesting. Usually when your system is opened up moister gets into it so you need to evacuate it to near 30" of mercury before pumping in new gas. That's what I've been told anyway.
Quang
  #7 (permalink)
Old 06-30-2001, 03:20 AM
air conditioning
i didn't say that i did it right, but it works awesome. i can imagine that the moisture might play a little bit of a problem but i live in arizona where the humidity is about .1%. also the engine compartment is so hot that it should evaporate all of the moisture that could get in there. it hadn't rained in arizona the whole time i had this hole in my discharge house.
  #8 (permalink)
Old 07-25-2001, 09:28 PM
TowerMaster TowerMaster is offline
TowerMaster is starting off with a positive reputation.
air conditioning
I had my 87 changed over about three years ago,And its still pumping 40 degrees at the vents! But I did fully evacuate the system, R-12 and R-134 DO NOT MIX. Its like having acid in the lines. And I used all the original parts...
  #9 (permalink)
Old 07-26-2001, 10:56 PM
pee wee pee wee is offline
pee wee is starting off with a positive reputation.
air conditioning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
