Slight knock in 351M - Ford Truck Enthusiasts Forums
Old 10-05-2004, 07:59 PM
TJ Shaw's Avatar
TJ Shaw TJ Shaw is offline
TJ Shaw is starting off with a positive reputation.
The 351M in my 1977 F-150 has a slight knock or vibration when it is warmed up at speeds of about 40 mph and above. The engine runs good, doesn't smoke, and doesn't use very much oil. The oil prressure gauge shows about 20 psi warm at idle using 10W30 oil. The pickup doesn't see much highway use. I mainly use it around the ranch off road. I've noticed this condition for about a year. I would appreciate your input.
Thanks, TS
Slight knock 302 Trombogon 1987 - 1996 F150 & Larger F-Series Trucks 0 05-04-2013 08:46 PM
engine knock problem FxRiZBeAsTLy 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-11-2010 11:45 AM
Slight engine knock FxRiZBeAsTLy 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-31-2010 03:53 PM
Slight engine knock, is it too late to replace bearings? gotjeepzj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-10-2009 08:14 PM
351m oil pressure problems systemofadowntox 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 01-10-2005 08:42 PM
Tags
351m, knock, knocks, slight, vibration, warmed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
