6.0 Powerstroke Bucking!
Hello out there....... Anyone out there besides me having trouble with their 6.0 powerstroke bucking and learching forward???? I have had this to a Ford dealer 2 times and they can not fix it....... By the way this is a 2004 and I have only had this truck for 4 months......... Any input, HELP
Mine will if you park it warm and let it sit 15 minutes or more. Crank it , put in reverse and it will "buck" at idle while you hold the brake and try to back slowly. Drop it in drive and all is fine when you accelerate. Sometimes does it in drive at idle when first started. Only time I have problem is on re-start.
Been scared to take it in for fear of a bad reflash!!
Mileage is 14.5 to 16.
2004 7,000 miles.
Les
2004 7,000 miles.
Les
Be sure to check out the 6.0 Bible…..
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
…. In the upper right hand corner of your screen, parts!
PARTS SHOP
Enjoy FTE
6-0 Power Stroke Diesel bucking and lurching
Yer, I have!! 5 months worth and many trips to the dealer without a fix. They finally, finally, brought in a Ford engineer and discovered wire chafing in the engine harness in the same places (2) that Ford "broadcasts" mention.
My truck is fixed and runs great, but I had already filed with DSB, in fact it has already been heard by DSB with no result yet. Incidently these chafing areas and pictures were posted on this site a couple months ago. Get them and bring them to the dealer. Not that it will do that much good if your dealer doesn't have a good cerified diesel tech.
Good luck. It is worth it. When these trucks run, they really run.
superduper, thanks for the info I am new (today) to this site....... running out of places to find answers..... thanks for yours i am going to print it and show it to the dealer on thursday (next appointment) i am not new to Ford trucks but i am new to this site and if you tell me where i can find the pics i will go there...... also what or who is DSB? Help and Thanks
You will learn more than you ever wanted to know
My truck was doing that symtom and also had a delay in engaging either drive or reverse from park.
After the usual dance with the dealer i finally had the tech call the ford hotline(the tech Bat phone of sorts) and lo and behold they ok'd warranty claim to change an internal tranny solenoid and fluid.
Perfect now even after lots of heavy towing and 12,000 miles.
Hope this helps..
6-0 Power Stroke bucking
You really don't need to spend a great deal of time looking up the "post" on the wireing harness suspect locations. Your Ford Service Dept. has access to the official FMC generated "broadcasts" in their computor and shouldn't have any trouble bringing them up. The offending areas on my engine were the left rear valve cover area and the right front valve cover area as per the Repair Order. They can be discovered by starting the engine and wiggling the wires in the suspected area and trying to duplicate the stumbling idle or surge. Go gettem.
There are Ford Technical Service Bulletins that describe "bucking and jerking". Here are:
Wire Chafing Issues:
A variety of driveability issues can arise from chafing/shorting wiring, such as crank/no-start, stall, running rough, misfire, buck/jerk or lack of power. The most common location for this is the valve cover/cover bolts near the FICM or the intake manifold bolts where the harness routes under the air intake hose. The harness should be rerouted and any chafe points insulated with rubber vacuum caps. Other chafe problems can occur where the sensor harnesses route around the valve covers, thermostat housing, idler pulleys, glow plug relay bracket, and near the accelerator pedal assembly (adjustable pedals), and also near the PCM by the battery and near the relay box brackets at the left rear corner of the engine compartment. On Econolines, also inspect at the top edge of the computer, along the oil dipstick tube bracket and auxiliary A/C lines. Broadcast Messages 1407 and 3077
Low RPM, Buck/Jerk, Miss, Stumble:
Some trucks built between 9-29-03 to 4-28-04 may exhibit these symptoms after decelerating down a long grade with the cruise control engaged. To service, the computer will need to be reprogrammed with the latest level calibration release, available with WDS release B31.11.
TSB 04-13-8
I would be talking with the service manager. Make sure that there is a certified diesel tech working on your truck. Ask the service manager to see the tech's certification.
Originally Posted by avi8or
Newbie here I have an 04 EX and since I had the first oil change my PSD does the bucking thing. I haven't taken it bak to Ford yet hoping to find some ammunition before I go. Now I'm getting 16.9 mpg overall by manual calculations and I don't want to loose that. 6000 miles.
Best of Luck,
Corey
Nope, it started before that...... had just moved from MA. to KY. and thought the temp. was the problem so I cahnged the oil........ it has been consistant since around the 5000 mile point....... called the ford dealership that I have been going to and they do have a certified diesel mechanic..BUT........here we go " he does not see enough of them to keep up" can you believe it.........so I am back at sq.1 and thinking of going back to MA. where people do see enough to know what is going on!
Best of Luck,
Corey
