6.0 Powerstroke Bucking!
Originally Posted by RealMenPowerstroke!
Curious bubba, but was it directly after the oil change, as in on the way home or starting the next day?? If it was yours is probably because they overfilled the oil and it is foaming. So one way or another you/dealer really needs to drain about 1-1.5qts.
Best of Luck,
Corey
Best of Luck,
Corey
Originally Posted by avi8or
I don't recall it happening the same day but definately the same week. I remember thinking "what could they have done." as I stood right next to the truck and watched while the mechanic did his thing and I saw nothing but an oil, filter change and safety check. No flashes or anything like that. I will check the oil level though.
Best of Luck,
Corey
Newbie here I have an 04 EX and since I had the first oil change my PSD does the bucking thing. I haven't taken it bak to Ford yet hoping to find some ammunition before I go. Now I'm getting 16.9 mpg overall by manual calculations and I don't want to loose that. 6000 miles.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
Enjoy FTE
Bucking, rough idle (sometimes) rough accelleration (sometimes)
Well, despite poor reviews i've read about the 6.0 I bought one. Love the truck, 2005 F-350, but after 4 months of ownership here's what i've come across. Truck was perfect, ran awesome and i got between 16-22 mpg, sweet! All of a sudden the truck loss accelleration, ran rough, and died 3 times in a 15 mile trip. I had the fuel filters changed and it was back at 85-90% but wasn't exactly right. After driving it for a while the idle began to shake the whole truck. 1/4 to 1/2 throttle, it ran rough and would shake badly as well. When you stand on it the roughness would go away, but it didn't have 100% of the power it did. Strangely this condition would come and go.
A friend of mine read that the EGR gets dirty and cleaning it might do the trick. The EGR was absolutely nasty and again better but not 100%. Pulling the EGR and cleaning it is easy and I was told should be checked regularly. After taking the truck to the dealer, and shelling out almost $2000, I was told the computer that controls the F.I. and one injector was bad. Hope this helps if you are having similar issues.
Own a 2003 350 6.0 which has the IPR and the ICP on the back of the engine. Bucking, lurching started and I drove it till the check engine light came on. Code showed a bad ICP. Since the IPR and ICP work together I replaced both. Truck now runs great, does not smoke anytime and mileage is now back to 19 MPG local. Truck will get 21 MPG on the interstate and I plan on keeping this truck. Best of luck!
Should you ever want to clean your injectors on a 6.0. I removed the fuel filter on the engine, removed the fuel in the housing, replaced the filter and then filled the housing with SeaFoam. Worked great for me. I also only use Motorcraft products in my truck. Seems like Ford has their act together on the oils etc. SeaFoam being the only exception.
