Offroad & 4x4
How to Mud/Snow/Water proof your rig
Old 10-08-2004, 01:14 AM
mustange70's Avatar
mustange70
mustange70 is offline
Today i pulled apart the starter on my 81 because it quit workin. Anyway basically what happened was it got very dirty and it was like a bomb went off inside the starter (it literary ran out onto the floor like sand it was in so many pieces)
Anyway what i'm trying to say is what the best way to mud/water proof a starter as well as the bellhousing, i did have a bead of silicon around the seems and clutch boot but it didn't work to well.
  #32
Old 10-08-2004, 11:44 AM
proeliator's Avatar
proeliator
proeliator is offline
Yea, I wouldn't use balloons either. Same concept though...its really so basic I'm surprised we haven't seen something like this sooner. I might have to give them a call about their accordian vent thingies...
  #33
Old 10-08-2004, 07:54 PM
bodabdan's Avatar
bodabdan
bodabdan is offline
Spray silicone is very handy to have around when it's wet. It doesn't contain the solvents that WD-40 has so it's very friendly to hoses and wiring. When I was growing up in Louisiana the big trucks would plug the hole in the distributor cap. The hole is there to let ozone escape out of the cap. Ozone is generated during the spark, and it can deteriorate some plastics. If you do plug the hole I would suggest not running for too long with it plugged. I wouldn't go over a day myself. I have also seen hi-mount accessory kits so your alternator can sit up even with the intake. You see these alot on street rods, low-boys, and stuff like that. Kayakers and cavers also use "wetbags" that can hold lots of stuff and keep it dry. They can come in handy. There is a marine electrical waterproofing that looks like tar. It's used to seal electrical connections on marine equipment. The only other trick I can think of is a combination of the hi-mount kit with an older Ford starter/generator mounted up high.
  #34
Old 10-09-2004, 01:23 AM
mustange70's Avatar
mustange70
I am going to have to get a can of that silicon by the sounds of it then. As far as the starter i was talking to my dad aabout it and he said to wrap it in duct tape, that is to tape all the open areas mud and water can get into. But i would think there would be problems with over heating. But it'll keep the mud and water out since duct tape is water proof.
One thing i've found that helps keep water out of the cab a little better is ussing another door seal superglued to the orginal one
  #35
Old 10-09-2004, 08:34 AM
bremen242's Avatar
bremen242
bremen242 is offline
what about taking the starter apart and using clear silicone on the mating pieces? that would probably help.
  #36
Old 10-09-2004, 01:43 PM
bodabdan's Avatar
bodabdan
bodabdan is offline
I just thought of something else- I have seen some Hitachi style hi torque starters that look like they would be very water resistant. HD motorcycles use a variation of this and they don't seem to have water problems. Hmmmmm...
  #37
Old 10-09-2004, 07:32 PM
rlh's Avatar
rlh
rlh is offline
Originally Posted by proeliator
Naturally, I know everything
Yeah, but do you know what is written on my avatar?
  #38
Old 10-09-2004, 08:35 PM
mustange70's Avatar
mustange70
The starter gounds itself through the starter body and i don't know if the silicon will prevent this, if it was sprayed and costed the ouside, then wrapped it in duct tape after it dries, or vice versa. As for the mini starters, it would work but it would propbably cost some money to get one made, but if you have a small block or a bigblock you could use a mini starter off a EFI truck, i have one on my flareside for header clearances issues, they seem fairly water tight but maybe someone with a newer efi truck can say something about this.
  #39
Old 10-18-2004, 12:14 PM
proeliator's Avatar
proeliator
Sorry, I missed this, I'm behind on my posts. It looks like I have two options, either admit that I DON' know everything...
Or surprise you by telling you that your avatar says:
"Time flies when you're drinking rum"
I didn't ask for these superpowers
Oh, and you are wearing beige boxers today
  #40
Old 10-18-2004, 12:23 PM
rlh's Avatar
rlh
rlh is offline
Close on the avatar! But way off on the boxers.
  #41
Old 10-18-2004, 01:12 PM
proeliator's Avatar
proeliator
Yea, it just occured to me that its "time flys when you're having rum". Sometimes my superpowers are a bit retarded, or maybe I had drinking on the brain...and for some reason they are only accurate with womens underwear. Hey, I tried
  #42
Old 10-25-2004, 08:26 AM
ShawnZ's Avatar
ShawnZ
ShawnZ is offline
I saw it too, I think it was september's or october's.
  #43
Old 10-25-2004, 08:28 AM
ShawnZ's Avatar
ShawnZ
ShawnZ is offline
note to self- read both pages before posting. X-p
  #44
Old 10-25-2004, 11:28 AM
Momudder720's Avatar
Momudder720
Momudder720 is offline
Correct answer:
Looks like we've got ourself a commando...
  #45
Old 10-25-2004, 11:32 AM
Momudder720
And as for waterproofing the starter/altenator, the best option I've found thus far is to simply buy 1 from AZ, then take it back.
"I dunno what happened. It worked just fine, then it just up and quit workin. Gimme another." Make sure to clean off the mud first...
I built a little guard deal that goes over the front of the air cleaner. The Busch swinger box worked great for a day, but I wanted something a little more bling, so I took a piece of aluminum flashing and riveted it to the front half of the air cleaner lid. Works like a champ.
Quick Reply: How to Mud/Snow/Water proof your rig
