in dash 6-disc Pioneer CD player - Ford Truck Enthusiasts Forums
Old 10-04-2004, 05:38 PM
streitdn streitdn is offline
streitdn is starting off with a positive reputation.
I just bought a pioneer 6-disc in dash cd player off of ebay for my 2002 F-150 FX4. I was told that the factory wiring harness chould just plug into the radio and everything would work fine. Well the factory harness doesn't fit into the radio..... any suggestions?? or is there anywhere i can get an adapter or something to make it work??
Old 10-04-2004, 07:42 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
Yes, you need an adapter. You should be able to find it at walmart or a car audio shop. The adapter plugs into the trucks harness and then you connect the correct wires from the adapter to the stereo's wire harness. You did get the stereo's wiring, right? If not you have another problem.
You can also check Crutchfield for adapters.
Old 10-05-2004, 06:45 PM
It is a Ford factory Pioneer stereo. is there a harness i can get from ford hopefully?? I know there is a harness that will connect to the wiring in the truck, just finding one for the stereo is the problem....
Old 10-05-2004, 07:17 PM
Oh, I see. I think you may have a problem. Your truck was equiped with the standard audio pakage and the 6 disk stereo is part of the premium audio pakage, that is why the plugs are different. You could still get this to work but you need to get the plug for the 6 disk stereo. Not sure if you can get this from Ford, but you could probably find it at a junkyard. Then you would need to splice the stereo to your truck's wiring. You could also solder some leads straight out of the stereo, if you can't find a plug.
Old 10-05-2004, 07:29 PM
Thanks....I hoped it wouldn't have to come down to that... good thing I majored in electronics, haha! I'm waiting to hear back from both ford and pioneer, so If something comes up thats easier i'll post it.
Old 10-05-2004, 07:35 PM
Well if your an electonics major, this should be a piece of cake!
2006 indash factory 6 disc player trmann 1999 to 2016 Super Duty 6 08-07-2012 12:40 PM
Making factory subwoofer work with aftermarket radio? LABulldog Explorer, Sport Trac, Mountaineer & Aviator 2 12-15-2010 08:19 PM
6 disc cd changer problems dtingle89 2004 - 2008 F150 0 01-09-2010 04:51 PM
2003 Expedition w/DVD - Help lockgirl Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 16 02-03-2009 07:46 PM
Econoline amplifier bypass???? asphaltjunkie50 1968-2013 Full Size Vans 0 10-06-2007 11:18 AM
Tags
2002, 2003, 6disc, 73, bet, buy, cd, disc, ford, indash, pioneer, player, stereo, superduty, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
