4x4 wheels on a 2x4 hub?
10-04-2004, 02:52 PM
on
Quick question. Will the f-150 4x4 wheel fit on my 2wd? Found a set of '04 4x4 aluminum wheels that look a whole lot better than my painted steel. Thanks.
10-04-2004, 03:09 PM
on
should work unless you have the HD package with the seven lug wheels. i believe there is only one 6-lug pattern for the 04's. 6x135mm.
10-04-2004, 04:24 PM
on
Sure will. I have FX4 wheels on my 4x2 and they fit perfect.
10-04-2004, 04:30 PM
on
I agree with 04fx4scab...those look exactly like my wheels, and I have the heavy duty package on my truck. That means a seven lug wheel. More than likely though Ford used the same blank to drill both patterns. I don't see an 8' bed on there so I'm guessing it isn't an HD. Only one way to tell..pop those lug covers off!
-aaron
10-04-2004, 04:37 PM
You guys are correct. All models of the 04 F150 use a 6x135mm rim. It doesn't matter if it's the 17" or 18". The only differenc is the xl or xlt that has the payload/plow package. These use a 7 lug due to the extra weight.
10-04-2004, 04:58 PM
on
Nope, i've got the regular 6 lug. Thanks for your help.
number2son
1999 to 2016 Super Duty
12-02-2009 10:05 AM
Bigbruce
11-19-2008 07:45 PM
dino360
10-28-2004 09:22 PM
cannonfodder
04-05-2004 07:20 PM
Charles-65F350
01-03-2001 08:02 PM
