FI fuel pum for a carbed 460
Greetings!
I have a stock '71 460 w/ Holley 750 carb, a Carter electric fuel pump located back by the tank and no mechanical fuel pump.
I just got an electric fuel pump from an '85 fuel injected Mustang. Which, I'm guessing, pump puts out a LOT more PSI than the carter. I think I'm getting 8-9 psi on the carter.
My questions are:
Will the Mustang pump put out too much PSI for my carb?
What, if any, damage will it do.
Thanks in advance.
Kevin K.
My questions are:
Thanks in advance.
Kevin K.
too much psi, carbs don't need no more than 7psi. the mustang pump is for a cfi and will probably run about 15 or so psi if I remember right.
if you run a regulator like you should be doing now the pump will just over work itself and burn out quickly.
Whats wrong with your current setup?
if its a stock motor you really can't beat a mechanical pump for price, simplicity, and preformance.
NateTheGreat
03-02-2015 05:37 AM
KJKozak2
04-10-2003 09:04 AM
