Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-04-2004, 07:59 AM
True2Blue True2Blue is offline
Garage is empty, add now
True2Blue is starting off with a positive reputation.
Merc pistons for a Merc crank
Hello all,
I recently acquired a merc crank for my 8BA flathead and I'm looking for the truth to piston requirements. In reading posts to this and other forums it seems more of an opinion than fact that you must run merc pistons with a merc crank. Does anyone out there know the truth? Just being an average Joe resurrecting a flathead for my '53 F100 I'm looking for the most bang out of my buck.
Thanks in advance for your advice and knowledge - Bill
  #2 (permalink)
Old 10-04-2004, 07:01 PM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Since the Mercury crank has a longer stroke the piston has to have the wrist pins set
closer to the pistons top or guess what they hit the head.
  #3 (permalink)
Old 10-06-2004, 05:33 PM
312 312 is offline
312 is starting off with a positive reputation.
ill back that up.
  #4 (permalink)
Old 10-06-2004, 06:09 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.4tl8ford has a great reputation on FTE.
The Ford and Merc Rods are the same the difference in the lenght of the stroke is made up by the rist pin placement as stated above.
If you try to use the ford piston with the merc crank its gonna get ugly quick. If you try to use merc piston with a for crank you get abot 2:1 compression
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1952 Ford F2 (Non-Stock Flat 6)
1997 Ford Explorer
Every Thing I've Ever Said Is A Lie
  #5 (permalink)
Old 10-14-2004, 03:24 PM
Many thanks for all your advice. Looks like I'llhave to keep my eyes open for a decent set of Merc slugs.
Bill
  #6 (permalink)
Old 10-28-2004, 08:30 AM
sosotwo's Avatar
sosotwo sosotwo is offline
1948 Ford F-100
sosotwo is starting off with a positive reputation.
I think I have a set of pistons for you 30 thou over sized
they are just about new
  #7 (permalink)
Old 10-28-2004, 03:47 PM
Thanks soso one!! Members like you make this site a restorer's dream. Now if I can just figure out how to contact you. Should be able to repond to you via email shortly.
Thanks - Bill
  #8 (permalink)
Old 11-07-2004, 04:48 PM
green53's Avatar
green53 green53 is offline
green53 is starting off with a positive reputation.
merc pistons
True2blue, I had a merc crank and pistons put into my '51 8BA. The whole bottem end and flywheel should be balanced as well.[IMG]flatheadpics0010[/IMG]
Tags
8ba, build, crank, flathead, merc, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
