2001 F250 4X4 NOT ENGAGING ESOF switch - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-19-2007, 08:38 PM
900rr 900rr is offline
900rr is starting off with a positive reputation.
what were your symptoms with the electrical and how did you solve them was there power to the wires at the motor with the fuses being ok p.s. what is the price on the motor
Old 09-19-2007, 11:26 PM
Benny2002's Avatar
Benny2002 Benny2002 is offline
Benny2002 is gaining momentum as a positive member of FTE.Benny2002 is gaining momentum as a positive member of FTE.
Check this connector and push it on HARD, sometimes it looks like its on but its not connected, cheap plastic heats up and wears out, push the connector on tight and hold it there with the truck running in park and have someone put it it 4x4 with the switch, went through hell to find out this was my problem a while back, it was on but not connected electrically.
<center>
<img src="http://i71.photobucket.com/albums/i149/bensbucket_2006/070821_192434.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
</center>
Old 09-20-2007, 05:05 AM
already did this check but it did not work
Old 09-20-2007, 06:05 PM
Benny2002's Avatar
Not to be a smart @#$ but did you hold it in, or does yours actually lock in place? Where do you stand with the problem right now? Uve checked fuses, relays, connections, new switch? The only thing left is the shift actuator motor. You could go to the dealer and have codes pulled for this, its stored in the GEM module. Cant retreive it unless you have Auto Enginuity or equivalant.
Old 09-20-2007, 08:33 PM
i have checked the connections and they are locked in i have wiggled the connetor and it is connected there very securley the six prong connector does have power the fuses are fine the relays are fine so now the truck is going to the dealership to be checked out but if any one has any new info it would really help thanks
Old 09-22-2007, 10:40 AM
just got the truck back the problem was that the connectors at the relays were corroded and needed new connectors put on and it is working just fine thanks for all the help
Old 12-18-2007, 09:42 AM
1pfieffer1 1pfieffer1 is offline
1pfieffer1 is starting off with a positive reputation.
Can anyone tell me how the vacuum hoses connect to the spindle? Is there a fitting or do they just slide over a nipple? My esof is on the fritz, won't engage and the HVAC blower is possessed at times.........
Quote:
Originally Posted by fedextech
have you checked your vacum hoses in the wheeel wells, that run from the frame rail to the spindle. they are bad about splitting and leaking vacum. sometimes the split is hard to see, ussually where the hose goes over the nipple. have a ford day!
Old 12-21-2007, 06:39 AM
Tim4265 Tim4265 is offline
Tim4265 is starting off with a positive reputation.
hoses in wheel wells
I'm assuming that after 4 days, you've already replaced the hoses....If not, I just replaced mine with neoprene. It's a pretty small ID, prolly 3/32" or so.
I can't remember. The guy at the parts store knew though.
It just slips on. I suppose though, if you suspect a vacuum problem, you might want to use a clamp, but I don't think you need to. It seals pretty well. and the fitting on top, that it slips on to, is plastic and would prolly crack if you use a clamp.
Old 12-21-2007, 08:37 AM
Thanks,
I got it into 4wd manually, one hub would lock with the selector on the hub but the other one wouldn't budge. I pulled the hub off and engaged it with a screw driver. haven't taken it out of 4wd since, too much snow plowing to do.......
I think I'm going to manual hubs anyway, do you know where the 2 vacuum lines from the jubs meet up and tie in with the rest of the vacuum system so I can block it off at that point?
Thanks again.
Old 01-25-2013, 09:53 AM
runninm runninm is offline
runninm is starting off with a positive reputation.
I have a 2002 F250 Powerstroke. Two years ago while driving long distance, the heating core went out and sprayed antifreeze all over the cab and electrical wiring behind the glove box. At this time, the entire instrument panel quick working. Got it home, heating core fixed, and dried out wiring. Instrument panel worked again. The ESOF however did not. When switched, the light does not come on in the dash, and there is no noise as to the air pump kicking on or transfer case engaging. Manually locking the hubs does nothing as well.
So my question is where the problem could be? Could the antifreeze fry that module behind the glove box or could it be something else? We've checked fuses; even swapping the two relay switches under the hood and nothing.
Old 01-25-2013, 11:18 AM
Musicman250's Avatar
Musicman250 Musicman250 is offline
Musicman250 is starting off with a positive reputation.
How ESOF works
Take a look at my post #9 on page 1 of this thread.
Old 01-25-2013, 01:26 PM
Thanks for your response. After doing more research and messing with the truck I am starting to think it is the 4wd control module that is located behind the glove box. I called it the wrong thing in my earlier post (GEM Module). Could the antifreeze have shorted this out and also is this a part I have to have a dealership program or can I just take the old one out and put a new one in without issues?
  #28
Old 07-05-2014, 10:58 PM
jsp_8701 jsp_8701 is offline
jsp_8701 is starting off with a positive reputation.
f250 4x4 problems
What did you ever find out was wrong with your 4x4?
  #29
Old 07-05-2014, 11:15 PM
f250 4x4 problems
ESOF maycraft19 1999 to 2016 Super Duty 9 11-27-2016 08:53 PM
Esof not engaging JDAD 1999 to 2016 Super Duty 0 10-19-2014 12:38 PM
ESOF Vacuum leak twayne85 1999 - 2003 7.3L Power Stroke Diesel 2 03-20-2012 03:03 PM
Another 4wd not working question johnnybecool 1999 to 2016 Super Duty 8 02-20-2007 08:52 AM
ESOF Not Working jheintze 1999 to 2016 Super Duty 13 03-15-2006 11:15 AM
Tags
1999, 2003, 4x4, connector, duty, engaging, esof, f250, ford, relay, shift, solenoid, super, switch, transfer, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
