Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 10-03-2004, 11:08 PM
jay leighter jay leighter is offline
Garage is empty, add now
jay leighter is starting off with a positive reputation.
Two Fuel Tanks
I just got a '73 SCS F350 with two fuel tanks. Is the main the front tank or the rear tank? And, the valve on the floor next to the driver...there are three "settings," which one goes to which tank? I'm having a hard time figuring this out, partly because I don't think the valve on the floor is working.
Thanks.
  #2 (permalink)
Old 10-04-2004, 12:54 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The main tank is the one between the frame at the Rear of the truck.
The auxillary tank is the front one mounted sideways.
  #3 (permalink)
Old 10-04-2004, 01:00 AM
73f350sc's Avatar
73f350sc 73f350sc is offline
73f350sc is gaining momentum as a positive member of FTE.73f350sc is gaining momentum as a positive member of FTE.
Hey Wecome to FTE,
I have one just like it. The rear tank it is the main the one closest to the cab should be the aux. As for the positions if the handle is turned toward the seat so the small pointed end is pointing toward the rear of the seat its in the aux. position , if its pointing straight toward the rear of the cab its in the off position and pointed forward is the main tank. There should be a black plate at the base of the valve that has the positions marked on them you may want to see if you have one and its just dirty. Thats what happened to me, it can kinda be tricky to tell if theyre working or not. i did it by just filling one tank for a while that way if I ran out it would tell me whether or not one or the other was working you can also pull the lines off one at a time and ee if gas comes out. Enjoy your truck its a rare model so take care of it, and let us see some pics too.
-Chris
__________________
73 F 350 Super Camper Special
84 Bronco II
Proud So-Cal Chapter Member since the dark ages
New Member of the Kentucky Chapter
  #4 (permalink)
Old 10-04-2004, 12:27 PM
biggreen78 biggreen78 is offline
biggreen78 is starting off with a positive reputation.
heres one for ya... after i bought the truk, on my way home I ran out of gas...(I filled both tanks completely up right after leaving the sellers home)...after dreading my gas mileage (only went about 200 mi off of $60 gas...or so I thought...the rear tank was still filled up) I poured even more gas in the rear tank (obviously not knowing it was still full) with all of the 2 1/2 gal that the crappy can could hold, but the truk did not start, i went all the way back to the gas station, and all the way back again and this time filled up the "auxillery" tank to which the truk started right up
to this day, I only fill up the mid tank and all is well
I noticed that the rear tank leaks gas and the tank selector switch when flipped to aux drops the gauge to empty immediately even tho it could be full of gas...how is this explained other than some redneck engineering
__________________
Pain Is Temporary, Pride Is Forever
  #5 (permalink)
Old 10-04-2004, 02:53 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Maybe the selector valve is bad? It should be mounted on the driver's side inside frame rail at about the start of the front of the box.
__________________
_____79 F-250 429 36" Cepeks____79 Bronco 400 35" Cepeks_____
  #6 (permalink)
Old 10-04-2004, 11:04 PM
quadrazer's Avatar
quadrazer quadrazer is offline
quadrazer is starting off with a positive reputation.
Brian Ward
Exclamation Selector valve
dual tank valve
When I switch from the back tank to the front tank, my fuel gauge switches but I still draw from the rear tank. Kinda the same problem you have just opposite tanks!
The problem with mine is the fuel tank selector valve, which selects which tank fuel is drawn from. This is obviously seperate for the tank selector switch in the dash. Just thought you would like to know.
__________________
My Trucks
1978 Ford F-350 S/Cab T/S
1998 Eddie Bauer Explorer
1995 Limited Explorer
  #7 (permalink)
Old 10-05-2004, 02:11 PM
It's precisely why I asked the question...the situation you just described. The sender was working in one tank (for the gauge) and the valve was working for the other (to get gas to the engine). The ford dealer got the valve working for my, so now I can get gas from both tanks. Wasn't expensive at all. I can live with the bad sender in the main tank. After posting my question and figuring out which tank was which (thanks guys), I'll just fill both tanks, run the main until it's empty and finish on the aux...the tank with the working sender. So long as I do that, I should not run out of gas...again.
Tags
1973, 1979, auxillary, camper, f100, f150, ford, fuel, rear, selector, special, switch, tank, tanks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
