You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Fordnut or anyone with experience running SVO, how would mixing a small amount of VO in a tank of diesel do? Someone in another post asked the same question. It would be nice to put 5 gallons or so in with a tank to offset the cost of a fillup. What kind of problems if any would be brought about by doing this?
__________________
01 F-250 Super Duty SB PSD, auto, 3.73 gears. All stock except SCMT tow safe, Ford severe duty AIS, Shortened filler vent pipe, CCV mod, Fuel tank pickup and pre-pump mods. Running on Homebrew Biodiesel.
I've done it on couple of occasions.. I mixed in 5 gals of SVO and filled up my tank with diesel.. Ran great! If I had an ample supply of SVO I'd mix it in when I filled up each time..
__________________
99 F250 SD PSD (Sweet!)
Frantz by-pass on Engine, Transmission, and Fuel Line
Mykro, how did you filter it before you put it in?
__________________
01Stroker, As long as it is prefiltered, you could safely run up to 50/50 with no problem. Even down to about 35 air temp. Before I went with the duel tank heated setup I have now, I was simply mixing WVO in higher and higher ratios, pushing the limits of what I could do without having to do all the rest of the stuff. During the summer I was actually running off of 100% WVO, or SVO, in the factory tank. Problem was it would gel up the factory fuel filter after a few hundered miles. Mix in some diesel, and I was good to go. I have started up on SVO at as low as 30*, though not easily. 40 is about the reasonable limit to start on unheated SVO. But again, at 50%, with well filtered stuff, won't be a problem. Keep in mind however, you will still face replacing the fuel filter at increased intervals. On the bright side though, one tank of 50/50, and you have already paid for that filter . I will expalin the viscosity part and how it affects our motors in the other VEG OIL thread a little later.
__________________
99 SD PSD, CC, SB, 4X4, Phantom gages, bypassed wastegate, a/p regulator to avoid defuleing, Home made SVO kit, Edge Evolution, 6637 air filter, straight piped exh, 15.2@86 1/4 mile
Thanks mykro and Fordnut74 for the replies! Fordnut, what kind of filter system would be adequate for what I'm wanting to do? Did you just make your own?
Thanks
__________________
