302 Valve lash adjustment? - Ford Truck Enthusiasts Forums
Old 10-03-2004, 11:11 AM
fordguy76's Avatar
fordguy76 fordguy76 is offline
fordguy76 is starting off with a positive reputation.
I recently acquired a well abused 1965 F100 originally a 223 now has a 302 with rattling rocker arms how do I fix this. I have a Hanes manual for 1973-1979 fords but cannot find any method for tightening the rocker arms. Any suggestions appreciated.
Old 10-03-2004, 12:44 PM
wizzard351's Avatar
wizzard351 wizzard351 is offline
wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.
if its a 302 all the ones ive seen ya turqe them down to 20-25 ftlbs but some of the ol 289's would adj.like brand x so im betin that this thing probably sat for a long while so id change out the lifters they probably colapsed makin for a noisy runin engine
Old 10-03-2004, 02:28 PM
fordguy76's Avatar
By the way the #'s above the starter are:
D10E-6015-AA
2C1
It also has 3 bolts for the balancer and crank pulley. Can you tell what year and size motor this is because I am not exactly sure myself.
Old 10-03-2004, 09:29 PM
wizzard351's Avatar
that would rule out 289 cuzz thats a 71 casting # the first letter d is for 70's and c for 60's then the #after that is the year like yours d1=71 so as far as the original ? if they are torqed down and still rattle look elsware ie.lifters,fulcums,valve tips,ect.
Old 10-03-2004, 10:26 PM
daggerNC daggerNC is offline
daggerNC is starting off with a positive reputation.
When I had 289's in my '65 Mustangs, the procedure for adjusting the hydraulic lifter based valves was first to get some old valve covers and cut the tops off. Install one and start the engine running (should be warm before doing this). Doing 1 valve at a time, loosen the lock nut until the rocker tip starts knocking on the valve stem/push rods, then slowly tighten until it just stops making noise, and then tighten 1/4 turn further. Do all 16 valves and you're done.
Now, there were other setups/engines that had solid lifters - those require lash setting. Other engines did have a fixed height and were torqued down as wizard mentioned above. You need to find out what type of valve train setup you have (sorry - I don't know too much about the '71 302's configuration assuming yours is stock).
Good luck,
dagger
Old 10-04-2004, 02:45 PM
fordguy76's Avatar
I dont have any extra valvecovers to cut up, so is there a way to do it without it running? When you torque them down to do you have to have a certain cylinder to top dead center?
Old 10-04-2004, 08:03 PM
urban_plowboy urban_plowboy is offline
urban_plowboy is starting off with a positive reputation.
If you have the rocker arms that are held on with nuts (not the bolt down type like on '79 heads for instance), I can recommend Comp Cams 4610-16 adjustable rocker kit. It's not rockers themselvs, but machined spacers that allow for adjustment, and a set of jamnuts to keep it there.
I run a Crane Energizer cam and it recommended having adjustable rockers. Seems to work great, it was my first valve lash job & I didn't know you had to preload them so much (more than 1/8 turn), so I think I can hear a loose one.
My contribution would be, re-assembling from a head swap or head gasket r&r, don't use silicone on the valve covers until you've run it & satisfied with it.
Old 10-04-2004, 08:29 PM
ga302p ga302p is offline
ga302p is starting off with a positive reputation.
Quote:
Warm the engine up. Turn the engine off. Pull one valve cover. Crank engine, adjust. Put valve cover back on. Warm engine up again. Do other side. I adjust all my hydraulics the valve covers off and running. It does not spray oil nearly as bad as you would expect. Have a fire extinguisher handy just in case you are very slow and get enough oil on manifold to catch on fire. I have never had this happen, but my cousin has. If it can be messed up, he will do it.
Old 10-04-2004, 08:57 PM
fordguy76's Avatar
I think the head set up is original '71 it has studs not bolts holding the rockers.
Old 10-05-2004, 02:50 PM
That's good, I know there's got to be people on the forums w/the bolt down ones so I won't tell you how errr, lacking, they are . The Comp kit is a good fix for these heads.
ga302's right about running it with the valve covers off, it won't spray out. Might slowly overflow out the lowest point if you leave it running for a while.
rocker arm kevinclark1990 1987 - 1996 F150 & Larger F-Series Trucks 3 06-02-2015 07:14 PM
rocker arm deve Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 03-18-2011 03:14 AM
loose rocker arms seafire 1967 - 1972 F-100 & Larger F-Series Trucks 3 05-03-2010 12:40 PM
Magnum Roller tip rockers and Solid lifter cam umdstang Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 05-08-2005 10:27 PM
rockers knocking tweakingit Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 11-03-2003 10:43 AM
Tags
16, 302, 4610, 69, adjustment, compcams, d10e6015aa, econoline, ford, info, kit, lash, preload, seting, valve, vavle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
