Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Indiana Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Indiana Chapter Join Chapter , Leader: KingBigJoe
  #1 (permalink)
Old 10-01-2004, 06:40 PM
F150'89 F150'89 is offline
Garage is empty, add now
F150'89 is starting off with a positive reputation.
License Plate
I saw today in Little Rock Ar a newer F150 today with Indiana plates and at the bottom of the plate it said "Truck 7,000" Whats that all about?
__________________
'89 F150 302 w/5sp
'89 S10 Blazer 4X4 2.8 w/5sp
'82 Buick Regal 3.8 auto
  #2 (permalink)
Old 10-01-2004, 07:27 PM
theologian's Avatar
theologian theologian is offline
theologian is gaining momentum as a positive member of FTE.
That sounds like a weight registration... F150 7,000 gross, F250 9,000 gross, F350 11,000 gross, etc...
__________________
Theo
'95 Bronco
and a few other things - Mack truck, Iveco truck, Goldoni tractor...
  #3 (permalink)
Old 10-01-2004, 07:43 PM
Chris_ce's Avatar
Chris_ce Chris_ce is offline
Chris_ce is starting off with a positive reputation.
Yes, but you can also get 9000# plates for a f-150 but it costs more.
__________________
1990 F350 DRW 460 E4OD
1978 Bronco custom 351m C6
1996 f-150 ext cab 4x4 eb 5.0 35/12.50/15 6in superlift
Indiana Chapter Leader
  #4 (permalink)
Old 10-01-2004, 08:39 PM
Thanks, when I saw the plate I figured that was a weight classification. Just wanted to be sure.
__________________
'89 F150 302 w/5sp
  #5 (permalink)
Old 10-02-2004, 07:54 AM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
Theo's got it right. The only problem is that you can just about put any plate on any vehicle regardless of its actual GVWR. I've seen 7k plates on Eagle Summit Wagons (yeah, riiiiiiiight, that'll move 7k), and I've seen passenger car plates on 1-ton vehicles. The BMV doesn't MAKE you plate properly. The only trouble is that when you get in an accident, an alert cop could give you some trouble if you don't have the proper plate for the weight you actually were at the time of the accident. And, yes, you can put a heavier plate on, but the heavier the plate rating, the more you pay.
Jason
__________________
-2003 E250 cargo 4.2L V6, 4sp electronic auto, 22 axle (work van)
-1993 F250 XLT xcab LB 351 2wd E4OD 4.10 open (parked, tranny issues)
Probably the greatest harm done by vast wealth is the harm that we of moderate means do ourselves when we let the vices of envy and hatred enter deep into our own natures.
Theodore Roosevelt
  #6 (permalink)
Old 10-02-2004, 10:47 PM
snowfighter's Avatar
snowfighter snowfighter is offline
snowfighter is starting off with a positive reputation.
you can over come some of the bumper laws nad lane widths with 16000 lbs tags
Tags
2003, 7000, ford, indiana, license, lisence, means, plate, plates, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
