oil pressure sensor location - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-29-2004, 01:46 PM
Bjon Bjon is offline
Bjon is starting off with a positive reputation.
Question oil pressure sensor location
First thing, GREAT SITE! Secondly, I'm trying to locate the oil pressure sensor on my 2001 Ranger XLT extened cab. It has a 3.0 V6. (VIN -U). Local dealership was no help. Oil gauge sticks when cold. Any info greatly appreciated.
Old 09-29-2004, 08:36 PM
Help I M Stuck Help I M Stuck is offline
Help I M Stuck is starting off with a positive reputation.
check the drives side of the engine towards the bottom near where the oil pan bolts up..should just be a single wire connector comming off it..might be below the steering pump..in that area..either way it's on the lower portion of the block with a single wire comming out of it.
Old 09-29-2004, 09:56 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
I'm thinking the passengers side, on the back of the block.
Old 09-30-2004, 11:57 AM
Thanks Ken, I'll give it another look.
Old 10-01-2004, 11:44 AM
Smile Found sensor
Thanks alot Ken! Found it with no problem. Replaced . Works great. Bjon.
Old 10-01-2004, 05:15 PM
mothra mothra is offline
mothra is starting off with a positive reputation.
I hate to threadjack but wher is it located on the 4.0 in a 2000 model?
Old 10-01-2004, 10:09 PM
Ken00's Avatar
I never looked for it on a 4.0 and I don't have my manuals tonight but since the 4.0 is based on the 2.9 try the drivers side of the block about a third of the way back, looking from under the truck.
Old 08-06-2009, 09:56 PM
rangerte rangerte is offline
rangerte is starting off with a positive reputation.
Is that on the back of the passenger side?It connects to an exhaust sensor too That oil sensor connected to O2 sensor on exhaust? Theres a connection on my oil pressure sensor that goes to the exhaust?
Old 08-09-2009, 11:26 AM
omontoya361 omontoya361 is offline
omontoya361 is starting off with a positive reputation.
where would oil sensor be on a 99 ford ranger 2.5 l?
Old 08-09-2009, 06:00 PM
luthrobediesel's Avatar
luthrobediesel luthrobediesel is offline
luthrobediesel is starting off with a positive reputation.
Quote:
Drivers side of block near oil filter. I think.
Old 08-09-2009, 11:43 PM
I Found It,I found It! Called Bro-In-Law,Said it was near bell housing right(passenger)side,below right cylinder head/bank!After 30years at various Ford dealerships,He oughtta know!Now he teaches Auto Tech at college! I'm gonna get him "Nice" Christmas present! Changed it out,but not a "Drop" of oil came out?I think someone mentioned hereabout testing the "old" one with VOM? I'll do a 50 mile drive tomorrow,to see if that fixes it! Or ,I gotta get that "New" gauge! Thanks EVERYONE!LONG WEEK of Posts&Threads!
Old 08-09-2009, 11:46 PM
P.S. It took me longer to get thatsnap connector off,then changing out the Sensor with a 3/8 ratchet&13/16" dep well socket,I think it was 13/16"?Butthat connector!!@#%^&**#@!
Rough idle, stalls when braking and steering at low speeds when warm justenuf2b 1999 - 2003 7.3L Power Stroke Diesel 48 12-05-2013 11:45 PM
2003 6.0 No Start Jnas860 6.0L Power Stroke Diesel 19 07-30-2013 03:54 PM
Sensors and Locations Hawk180 1999 - 2003 7.3L Power Stroke Diesel 4 12-21-2012 09:06 AM
frame rail fuel pressure high css4608 Escape & Escape Hybrid 4 08-19-2010 06:42 PM
oil pressure sensor location? davidson07 1999 to 2016 Super Duty 18 05-15-2002 10:58 AM
Tags
2002, 30, 40, 89, bronco, ford, ii, location, oil, oli, pan, pressure, ranger, sensor, size, switch, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
