Power Window slipping on '88 E150
Hi, my driver's-side window is slipping when actuated by the power-window motor. I have the door panel off and can see the sliding actuator arm getting budged, it just doesn't seem to catch enough to move the window (up or down). The motor sounds like it's spinning but that's about it.
Is there a clean way to get at the motor/worm gear to troubleshoot this? There's not much of a hole or space in the van door.
Thanks.
Dan
Thanks.
Dan
the bushings in the motor gear housing are worn out ... There are 3 small nylon Bushings.
there is a kit you can buy to repair this...You used to be able to get a kit from Ford, i havent checked lately.
You migh also check with Autozone, etc...
i found my last kit on ebay $4.99... i have a 91 E150.
I had the same problem on my '92 E-150, eventualy the cable jumped off the nylon runners and got tanggled in the gears. I bought a complete window regulator and motor together for approx $130 about 5 months ago from www.partsamerica.com.
hope this helps
Steve
hope this helps
Steve
sounds like the plastic gear on the motor is cracked.
i had the same problem on my van, replaced it and the
other window failed 2 days later.
i recall a quick grip clamp being useful in holding the window
while getting the mechanism in and out of the door, which is
a real knuckle busting pain.
i also bolted it back together, and taped the nuts to an open
end wrench to make them easier to get back on. you'd like
3 hands to do this job.
