ZF 5-spd leaking fluid out of the top of the case?
Old 09-28-2004, 10:21 PM
bryan_johnson's Avatar
bryan_johnson
bryan_johnson is offline
Post ZF 5-spd leaking fluid out of the top of the case?
Hi guys,
I have been noticing that the 5-spd in my 94' F250 (it's the ZF gearbox) has been leaking fluid. It's getting all over both side of the transmission, and when I wipe it off it comes back.
The only place that I can seem to think it is coming from is the top of the case? I haven't taken off the shifter boot but is there any gasket and/or seal up there that wears out? The dealer has not been great help on this one.
Thanks,
Bryan
Old 09-28-2004, 11:06 PM
n578md's Avatar
n578md
n578md is offline
There are two gaskets on top of the transmission. There's one between the case and the shift tower held on by 8 bolts and a small one between the shift tower and the gearshift boot retainer plate held on by four bolts. Maybe the bolts just need a tightening? That's kind of unusual for a ZF S542 to do that. The Mazda M5R2's have a history of leaking from the three shift rail plugs at the back of the shift tower. Are you sure it's an S542?
Bryan Goss
02-24-2017 06:23 AM
Bryan Hagan
1999 to 2016 Super Duty
11-25-2016 11:32 PM
carltonwebb
07-31-2016 01:17 AM
catbird7
Oil & Lubrication
09-23-2006 12:56 AM
bryan_johnson
06-06-2004 08:47 PM
Quick Reply: ZF 5-spd leaking fluid out of the top of the case?
