Dually truck box
on
check out this page, they have several styles to choose from. http://www.chromewheel.com/fenders.htm
73-79 Dually truck bed
Or do what I did, build one yourself! After I converted my single rear wheel to a dually rear end, I bought the fiberglass outer fenders off of an 87 Ford Stepside for 60 bucks from the salvage yard which had flat sides where they mounted to the 87 truck bed. I ground the fiberglass sides to match the contours of my 79 and then fiberglassed my own mounting brackets to the inside of the fender. I mounted studs to the side of my bed and bolted up the fenders with a thin poly weatherstrip between the fender and the bed side. A LOT of work, but I saved a good amount of money and I love the way it looks! Good luck!
Dean06919
03-29-2015 08:12 PM
