400 Valve Train Troubles (Bent some pushrods, 5k on motor)
Okay, I bought a motor that has about 5000 on the rebuild. Its a 77 400. I bought it from a guy who I trust, but he didn't build it himself. I am quite positive it has a performance cam in it, judging by idle and hp curve, and just by how high it revs, it revs real high for a 400, and has a lot more power than the 11.5:1 compression 460 I had in my other truck.
The problem is this, first time I took it wheeling after I got the motor in, I got on the gas hard (but not overrevving it at all), and it started backfiring and I had a ton of noise out of the pass side valvetrain. So i towed it back, pulled the valve cover and found 2 pushrods that were really mangled up, both on the rearmost cylinder.
2 things come to mind:
1. Are the valves to tight in the guides (cause of hte recent rebuild)?
2. Is the cam lift too much for the valve springs and or rockers.
Any other Ideas?
I really want to check out the second idea, I was wondering if there is an accurate enough way to check the cam lift without pulling the cam out?
Also, any other thought on what may have caused the 2 bent pushrods on the same cylinder would help.
Any other Ideas?
If the valves were sticking you would likely have a destroyed engine. (done that! )
Lift can measured with a dial indicator... measure the lift with the rocker off... that is the transit of the unloaded push rod.
Perhaps also the preload was over-looked on this one cylinder? but check them all. GL
BADASS 65 RANCHERO
03-27-2014 12:33 PM
Jayman1976
07-26-2013 06:41 PM
jazzy66
01-13-2005 06:36 AM
