leaves
The A/C system draws air in through the vent in the cowl, right ahead of the windshield. It isn't uncommon for junk to accumulate in there, although there is typically a screen that is supposed to keep large objects out of there. Since the cowl cover on a Ranger is part of the cab sheetmetal, I assume you probably have to pull the A/C-heater box out to clean this out.
Bart
Bart
i had the same problem with a 88 i had,,, i noticed on a 89 that they went from slits in cowl to holes,,,,on 88 i found a plastic gutter screen cut it to length and used plastic ties and put over slits in cowl helped a whole lot in elimating leaves in cab,, a side note if you get too much stuff and leaves in blower area it will stop up screen there and a/c and heat wont work right, making blower motor over heat,,, a buddy of mine seen how i had mine and he took off windsheild wiper motor and put his on inside of cowl, he said it was a pain but now no leaves and trash in cab,,,,, hope some help here
01 Ranger
1983 - 2012 Ranger & B-Series
04-15-2004 02:41 PM
62BigBlue
02-09-2003 07:37 PM
