2001 Ranger 3.0 to 4.6 Swap - Ford Truck Enthusiasts Forums
Old 09-27-2004, 08:13 PM
aaron318 aaron318 is offline
aaron318 is starting off with a positive reputation.
I just bought a 2001 Ranger with a 3.0 V-6(dog) and wondered if a 4.6 Mustang GT V-8 &AOD would be a difficult swap.
Old 09-27-2004, 08:38 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
As far as I know, the mod motors are humongus, I have doubts as to if it would fit.
Old 09-27-2004, 08:47 PM
Question
Correct me if I'm wrong, but hasn't the 4.6 been available in Explorers since about '96 or 97? I thought the Ranger and Explorer were a very similar platform....
Old 09-27-2004, 10:36 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Nope. They quit that when the sploder went to unibody in 98.
Yes you can stuff a 4.6 in the Ranger, nobody makes anything for it, and you'll need to be a fairly good welder to accomplish this.
If you do it and take pictures and do a write up, I'll give you $50.
Old 09-27-2004, 10:46 PM
Thanks for the reply, doesn't sound like the finest of ideas.... Are there any successful V-8 swaps for 2001+ Rangers without an engineering degree and or a monster garage crew?
Old 09-27-2004, 11:44 PM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
The 5.0 is still good for 2001 as far as emissions with the feds and was in the Exploders until the most recent sissyfying in 02 when the 4.6 came in.
The 4.6L can be put in a Ranger, IF you call the Lightning Bolt a Ranger (it IS in NAME ONLY in that case) and you get Ford's blueprints for that.
The F150s have to have the cab pulled from the frame to service the heads (well, the factory recommends that) so I doubt the Ranger would fit that engine too easily.
Old 10-15-2004, 02:51 PM
superjfly's Avatar
superjfly superjfly is offline
superjfly is starting off with a positive reputation.
Are you implying the 4.9L or the 5.0L? What year's V8s with the most HP would fit in what year Ranger? '98 and up?
The best I've seen so far is the 4.9L (215 HP) from the Explorer or 4.9L (235HP) from the '93 Mustang. Are these compatable?
Thanks
Old 10-15-2004, 05:53 PM
NascarNut's Avatar
NascarNut NascarNut is offline
NascarNut is starting off with a positive reputation.
Quote:
The only 4.9 that Ford made was the 300 six. Yes, technically the 302 is 4.9L but Ford wanted to distinguish it from their strait six.
Engines out of 1989-1993 Mustangs and Explorers with the 302 are the most commonly used but any year 302 would work. For a '98 and up Ranger I personally would dig one out a 'sploder.
Old 10-16-2004, 01:01 AM
Drizzt's Avatar
Drizzt Drizzt is offline
Drizzt is gaining momentum as a positive member of FTE.
i've got an 88 5.0 from a mustang in my ranger.
to put the question to rest:
you will never be able to fit a 4.6 under your hood unless you plan on re-doing almost everything including moving the firewall back. ford (it might not have even been ford. i believe it was SLP) did produce one lightning bolt with a supercharged 4.6 in it but redid everything including widening the frame and a whack load of other stuff. it was pretty much a ranger body on a lightning frame
Old 10-19-2004, 09:33 AM
superjfly's Avatar
Quote:
Would you dig it out of a 'sploder because it would be easier to install, or because of the computer? Would the fact that my truck is a 5-spd make a difference? I don't think the 4.9L Explorers came with manual transmissions.
Also, wouldn't the older engines be easier to find parts for? Exhuast, etc... I suppose after the swap most anything would be custom fit.
Thanks for the help.
Old 11-05-2004, 01:07 AM
Ranger_351w Ranger_351w is offline
Ranger_351w is starting off with a positive reputation.
For what I have seen so far swaping any mod motor into a ranger is going to be a quit a chore the mod motors (4.6/5.4 sohc or dohc) are just shy of 31 inches wide at the valve covers. Which puts the left (drivers side) head on the wrong side of the power booster/master cylinder not to mention steering linkage headers should not be a problem just route them to the outside of the frame rail (fenderwell headers) steering should be an easy fix by switch to a mustang style rack and pinion behind the front suspension instead of infront of it. That leaves the master cylinder problem still working on that issue since my 5.4 dohc is going into a 94 ranger with drive by wire hydraulic steering (4x4 on 49 iroc's with custom 3 link front and rear) I am considering an under the cab setup like they used in older jeep cj's. I'll keep you posted now that my life is somewhat back to normal after all these damm hurricanes.
Old 02-10-2014, 06:30 PM
coolman.1971 coolman.1971 is offline
coolman.1971 is starting off with a positive reputation.
it been done
I know this post was some time ago. but just to let u know I have put a 4.6 32 valve. out of a 96 Lincoln. witch we all know is a dual over head cam engine. it fits like a glove. the only thing a had to remake was the a/c box. so let me tell u it can be done.
Old 02-11-2014, 07:27 AM
tonymontanna1983's Avatar
tonymontanna1983 tonymontanna1983 is offline
tonymontanna1983 is starting off with a positive reputation.
Pictures or it didn't happen^^^^^^^^
91 Ranger Transsmison swap Shannon Roe Ranger & B-Series 1 04-05-2014 10:02 PM
2001 ranger 4.6 swap Allstar recovory Ranger & B-Series 19 01-26-2014 01:50 PM
Anyone swapped a Explorer V8 into a ranger? NJohnstonMN Ranger & B-Series 9 01-11-2011 12:14 PM
3.0 ranger to 3.8 mustang engine? clewis4.6 Engine Swaps 1 06-11-2008 07:10 AM
94 ranger engine swap chivo1944 Ranger & B-Series 24 05-20-2008 06:39 PM
Tags
1999, 2001, 30, 302, 42, 46, engine, explorer, f150, f150swap, ford, headera, mustang, ranger, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
