Spark Plug Replacement
Originally Posted by motochris
Most of the time when you hear of a plug blowout, it's after the plugs were changed or checked. At least thats what I've seen.
The jury is out on whether to use anti-seize on plugs. Ford didn't use it on their initial installation. A lot of Ford mechanics don't use it; and torque the plugs to 18 lb. I used anti-seize very sparingly, and cut the torque down to 15 lbs. I will go over them again in a year, just to make sure that they continue to be properly torqued.
Ford has redesigned the plugs, allegedly to fix the blowout problem. One of the problems with the old plugs was the finish, which would lead to premature loosening of the plug unless the stuff on the shoulder of the plug was sanded clean.
Was there ever a comittee formed to look at the use of anti-seize? I know that there has been (since the dawm of time, I guess ) a problem with material contamination between carbon steel and aluminum/alum alloy; hence, the need for anti-seize.
As far as the surface finish: I agree to a certain extent, but to further the cause – the seating area on the head for the plug must mate the plug seating area itself.
Clear as mud?
Hi Lars and welcome to the forum
The 05 uses a different spark plug design than the earlier ones so hopefully there wont be problems with them. I haven't heard of any so far anyway.
Ron I've replaced lots of plugs in the modular engines and have never used anti-seize on them and haven't seen any problems because of it. One of our Ford reps told us not to use it because it can cause ignition problems. I really didn't buy that but I figured that if they didn't use it from the factory it was probably ok not to use it. I think it's probably a case of doing it how you feel it should be done and neither way is wrong.
Lars,
I have a problem with the whole plug cavity/thread-length-in-head design in the first place - pet peeve, ya' know. Plug blowout is not recognized as a problem by Ford - bottom line.
I think that they have tightened inspection on plug installation and torque, though. But, let me say that I have not seen nor even heard of plug blowout around this part of the country, so I'm confident that the installer and his methods are the key.
Dave,
I can't see how anti-seize will damage anything either - if you use it only on the threads and not let it get into the cylinder. And I can see how using it could be a security blanket.
Maybe one day we'll find out why some blow and some don't.
Dave,
LH!,
No I don't other than a Ford Tech saying he heard that 2003-04 there was a head change to increase the number of thread retaining spark plugs. But, don;t go to the bank with that one because you and I know a lot of BS floats around dealerships. I can say I have not heard of a 2003-04 V10 blowing plugs yet. There have been several I know about 2002 and down.
I just changed my plugs on my '99 F250 V10. And let me say I had one plug blow out after replacing them. Got me thinking maybe I should check all 9. Did so, and they were fine. I guess and didn't torque that one plug enough. I bought a new plug and retorqued. By now the truck runs fine. I guess if I would've taken it to the dealer they would've told me I needed new heads when afterall I didn't torque the plug to it's specifications. I'm just a young mechanic learning the new technology of FORD.
