Brakes problem in 88 7.3L: Master cylinder or vacuum pump??
In my 88 7.3L, the brakes just pretty much went to crap while driving on the highway, I think somehow triggered by having to drive on rumble strip for a good 2 miles at 55mph due to construction. Pedal became really soft, then eventually became hard, and sometimes goes back to soft, but the truck never stops like it used to.
I was wondering if someone could tell me how to tell if it's the master cylinder or the the vacuum pump. I have a feeling it's the vacuum pump, because I can brake better at highway speed, due to the pump getting enough power to feed the brakes, if my understanding of the system is correct. Let me know if this is a correct assumption. I NEED BRAKES!!
Thanks.
Eric
Thanks.
Eric
I have the same exact problem. I just posted a thread a couple days ago and Dave told me the vacuum pump was crap but when I checked it at idle it had a good vacuum. I am going to replace the power booster to see if it helps. I first tried replacing the master cylinder but that did nothing. When the pedal gets stiff it is near impossible to stop! Let me know if you figure something out. I cant drive without the brakes.
The vaccum pump is also the lift fuel pump. There is a fairly large (~1") black hose that runs from the pump to the break booster. When I checked my vacuum pressure I just unhooked the hose from the booster unit. If you start the truck and put your finger/thumb over then end of the hose it should be sucking fairly hard. If you have or can get a vacuum gauge the pump should be pulling at least 7 to 10 inHg if I recall (someone correct me if those arn't the right numbers)
Hope that helps
Hope that helps
still sounds like it might be the vac pump possibly the pulley slips and then when it catches then you get vacuum. i have seen this before. How many miles are on the truck? have you ever replaced it before? when the brakes feel normal when you step on them do they grab and kinda give you whiplash? if they grab or lock up it could be your R.A.B.S. valve.
Cool, yes 215,000 miles. Dont know when replaced as I have only had the truck for a year. I have noticed too that the rears do seem to lock up over the last 2 weeks more than they should, but no, the brakes are not jerky or unpredictable. I thought the locking up may be an adjustment issue. I will look into the vac pump and adjustment first. Thanks.
Hawkmcgee
08-26-2014 08:07 PM
WEST AUSSIE 94 250
08-11-2014 10:15 AM
